There is much that is false in the link
Bill Tindall
>Most egregious is claim of oxygen deprivation in cold weather. It takes a minuscule amount of oxygen to cure a varnish coating. If what was said was true Minnesotians would be passing out from lack of oxygen for most of the winter. An oxygen molecule travels on the order of inches in a second just by diffusion. Convection is irrelevant to replacing oxygen at a curing surface. I would venture, not taking the time to calculate the situation, that the replacement rate of oxygen at a curing surface is orders of magnitude greater than the rate it diffuses into the film to react with the varnish components.
Second, the claims on viscosity are similarly wrong. The viscosity of polymer solutions such as varnish are extremely sensitive to dilution. I don't know the value for varnish molecules but, for example, diluting a solution of cellulose nitrate by a factor of two will reduce its viscosity by something like a factor of 50! The effect of temperature is vastly less. Leveling is all about viscosity, less leads to faster leveling (and runs). If the varnish seems to thick because it is cold either heating the varnish or thinning with a small amount of solvent will solve the problem. Thinning with something volatile will enhance the rate of evaporating the solvent, and that is good in cold weather. Thin with naptha. Ditto for any of the other finishes. Thin with a low boiling point solvent or hell may freeze over before the solvent leaves the curing film. But be wary about the possibility of blushing if the solvent leaves too fast.
A third factor was discussed by our own expert in these matters, Mr. Dresdner. The catalyst that accelerates the curing is deactivated at high humidity. Cold can mean damp, (except in MN where cold means no humidity) so cold and damp is a double whammy to cure rate. How much humidity affects the catalyst will depend on the catalyst used in the formulation. Some are probably less humidity sensitive so some products may cure better cold and damp than others.
Indeed, the chemistry that results in "cure" proceeds at any temperature at a rate dependent on catalyst activity and temperature. It is the same chemistry that makes fat rancid. Whole wheat flour gets an off taste quickly at room temperature because of the fat becoming rancid(oxidizing/reacting with oxygen) but I can store whole wheat flour for a year in the freezer and the fat stays fine because lower temperature has slowed the rate down orders of magnitude. The varnish has a catalyst that makes the "fat" oxidation go faster so it may not take a year to cure at 40 degrees.
The temperature factor affects many of the physical and chemical process involved in cure. However, I can't think of any reason the final film properties should depend on temperature of cure, unless the temperature is too hot. Most polymer cross linking reactions (and that is what is going on) are more complete if they go more slowly (think epoxy cure). But curing is a complicated process and someone having experimented with these issues may have contrary data. I would believe the data.
