O/T-Wireless Question-
Ken Oakley-Sunny St. Cloud,Fla
>We have a Linksys router setup so my wife can use her laptop anywhere in the house. I have an older Dell desktop,(4500C) I would like to make wireless compatible. I know I need a plug in adapter. Do I need a Linksys or can I use another brand?
Re: O/T-Wireless Question-
>A signal is a signal. You can use other brands. I've got my desktop plugged in to my wireless router though. The laptops are wireless.
Jesper, Denmark
Jesper, Denmark
>Ditto - two PC's wired and one laptop wireless. The wired IS faster! Maybe that is not relevant if you do not have a fast connection. 6 Mbit download and 1 Mbit upload is almost minimum standard around here these days.
Jason Roehl in Lafayette, IN
One caveat...
>...is that the wireless router and the wireless adapters have to use a compatible standard. Available are 802.11a, 802.11b, 802.11g, and pre-802.11n (the n standard is not yet released, but there are many products available with something that is close and will likely be the standard or compatible with it). Most products have multiple compatibilities, but may not be compatible with them all. 'A' is archaic and slow, dual compatibility of b and g is becoming less common in favor of n, but usually the n products are backwards compatible with g and sometimes also b.
For instance, I bought a new wireless router a few months ago, and after many dents in the wall from my head, I figured out that the ancient wireless adapter I had hooked to my Xbox 360 was a-only, and my wireless router didn't like it. So I bought a long network cable for the Xbox instead.
Jason
Why?
Dustmaker Mike
>if you are plugged into the router you are just fine. If you can get a cable to the router you will be better off. Wireless is great for laptops because they move around the house so much, but a desktop just sits there and does not move to much. With all that said Wired is faster then Wireless and is more secure.
Re: Why?
>My cable co. informed me I can not plug into the modem without a splitter or some such thingie. The computer had been set up for wireless by the person who donated it to me but couldn't remember where the adapter is. She will find it 10 seconds after I purchase one
Wireless Router I think
Dustmaker Mike
>should have extra ports. Depending on the router there will be 4 ports on the back you should be able to plug the desktop into. What model number is the wireless router? We should be able to look it up and see what can be done for you.
Re: Wireless Router I think
>Linksys Wireless-G Broadband Router-Model WRT54G2
GalenV in Iowa
>Ken
That is the model I have and it should have four connections for wired devices plus the seperate one that goes to your exterior modem. You just need an ethernet cable to connect from the router to your desktop computer. The manual with the Linksys router should show you this type hard wire connection and software to set it up.
You say the desktop unit was set up for wireless so is the Linksys PCI adapter already mounted in the computer and it should have a stub antenna attached to it. Could go that way but hard wire is better.
Galen
Re: Why?
Dan Donaldson
>Someone is blowing smoke ;-)
Dan Donaldson
>With any luck, if you plug in the ethernet cable, it may just work. If not, go to the control panel, find the network wizard and it will guide you through the setup.
I hope not me?
Dustmaker Mike
Dan a question
GalenV in Iowa
>Dan
With the computer that I hard wired through the router on the intitial setup it had me connect the computer direct to the qwest exterior modem and install a quick connect install CD. I assumed it had to be done to make the computer recognize the modem and my internet service. Then it had me plug the computer into the router and the router to the modem (router then in series)
Was this first procedure really not needed and would the plug and play feature recognized the system if I had just skipped the first direct setup?
I get a better signal on this wireless computer from the house next door than from the router downstair? I see how wireless is somewhat unsafe!
Galen
>Last night I did something I should have done in the beginning. I went to the Linksys website and downloaded a users guide for the router I have. From what I read there are ports on the back of the router I can plug cables into that can plug into the computer and I am in business. I did not receive a users guide with the router and don't recall one being on the installation CD.
Boy I love my computers but I also hate them.
Thanks to all who responded.
Re: Dan a question
Dan Donaldson
>Probably depends. If the isp requires mac id authentication, then there may be some setup required, otherwise, it would probably just work. A lot of the time, that setup is just them installing a customized browser and some other stuff that may not really be needed. Most of the time, if I am setting one up for someone, I try first without their stuff and if it works, I don't ever install it.
No, the ISP rep
Dan Donaldson
Cat 5 Ethernet
Dustmaker Mike
>cable is all you need. They will have an RJ45 plug on each end. Don't get the high dollar stuff it is Not needed.
Gary Evans--Tallassee TN
>Hey Ken,
Like most everybody has said, wired is faster, but you are going to have to have a network card in your computer in order to hook directly to the router.
If you don't have one, you can buy a wireless adapter from Linksys at Walmart that will plug into a USB port. You don't have to add a wireless card or a network card unless you want to.
Gary
Re: Cat 5 Ethernet
>Mike- I don't have any high dollars- I'm as tight as a Crabs A$$hXXe when it comes to spending money
Dan Donaldson
>Depending on the age of the computer, most of them have built in ethernet any more.
Couple Things
David Yoho
>Ken, if your computer has a jack on the back of the case for a RJ45 plug to fit into, it means your computer already has either an OEM built-in NIC (network interface card) or a stand-alone NIC that mounts into a slot on the motherboard installed.
If not, then you'll need to open the case and see if there is an open (most likely PCI - identified by its white color) slot available to add a NIC, which usually costs less than $25. This is only necessary for going the 'wired' route.
If going wireless, unless you purchase a USB wireless adapter, you'll still need an open slot on the motherboard for a PCI wireless NIC to plug into.
Personally, I prefer the wireless adapters that mount inside the case on the motherboard. In the absence of an available slot or you just don't feel comfortable with going inside the case, a USB adapter is the way to go. We have three computers here that are wireless and two that are wired. I use a Linksys WRT54G router. I prefer a wired connection for its speed and security but have no choice about using wireless on the three that are.
THE most important thing to remember about going wireless is it will work just fine BUT it's not worth using at all unless it's SECURED. An unsecured wireless connection is just inviting trouble. It's like going on vacation for a week and leaving your front door sitting wide open!
The router you have supports WPA and WPA2 security, as does WinXP. Don't use the weak-as-water WEP choice, since it's no better than leaving the front door half open. Employ a good strong WPA pass-code or password and write it down so you don't forget or lose it for down the road. The instructions for your model router should explain the sequence of setting up your security.
Again, given the choice, I think you're better off using a wired connection for the desktop. If the computer is not already setup for it, the cost is minimal and well worth it.
David
