Sort of OT - Sawdust on snow?
>Anyone ever use sawdust to provide extra grip/traction for snow/ice?
Did it work reasonably well?
Re: Sort of OT - Sawdust on snow?
Roy C. Gryder
>Just tried it last week. Helps some. Not as good as sand but better than nothing. R.
chuckbeck in cent il
>I was just wondering too. I sawed an ash log in half to make some snow steps and I pushed the shavings all around. They seemed to work for a little added traction, but didn't have enough weight to keep from blowing away and tracking through the house. I may throw a bucket-o-shavings in my back seat in case I get stuck.
chuckbeck
Robert R. Clough - Thorncraft
>I've used it and, yes, it does work. It works best, in my experience, when the temperature is around 30 - sawdust then kind of melts into the snow. Works ok on ice at the same temps.
John Veerkamp, Western Mo
>the best traction maker I've is wood ashes rather than sawdust. It even helps to melt the nasty stuff.
non-clumping cat litter box sand
Ray Newman
>A bag of non-clumping cat litter box sand works extremely well. Best to store it in a plastic bag in the trunk, cab, etc.
The clumping style can harden in the bag if there is enough moisture in the air.
Dave Bair, Eaton Rapids, MI
>I prefer 20-20-20 fertilizer. It melts ice pretty well and doesn't kill the grass like salt. Saw dust works for traction purposes but ends up getting tracked into the house if you have snowy boots. And, no, you don't leave your boots outside the house; they get cold and it's like putting on ice blocks.
WWII Secret Weapon
A. Kapocius
>During WWII, a British scientific wizard came up with a sawdust and ice concoction for "iceberg" aircraft carriers. In a demonstration for Winston Churchill, he fired a .38 at a block to demonstrate its bulletproofness. The bullet ricoccet about the room and almost done Winston in.
A large block of sawdust and ice was made up in Canada to prove the concept. For whatever reason, the project was dropped. As late as 1980, the block was still melting away on the shores of Hudson Bay.
Al Kapocius
Re: WWII Secret Weapon
Randy Johnson
>I bet that would have made for some interesting landings.
