Severe shop Moisture Problems
David Frame
>Hi Ellis and David and the WoodCentral Family,
Living in Louisiana in not an easy place to keep my cast iron tool tops looking like new. Their are many oxidation stains and some minor rust, with very little pitting, on all of my tool tops.
I've have been asking around about chemicals to remove this dilemma that exist. The one
that keeps coming up is phosphouric acid. However, it has been suggested to me not to use this material because it opens the pores in pig iron, basicly giving it makes more room for the tools to rust. I do know that once my tools are cleaned, they have to be sealed with something like Top-Coat or some other means, such as wax, etc...
I normally don't have this problem because I am able stay ahead of it.
I fractured my foot in 4 places on December 1st and have not been able to keep them clean.
>From December 2nd to December 21st of 09 it rained in my area in of Lafayette, LA nonstop. It was like a mist in my shop and the concrete floor had water oozing from it. The only thing I was able to do was to wipe all the tools as dry as possible and displace the moisture with WD-40. I am continuing to use this displacement method. My tools are still full of gunk and not ready for use.
I do have some small sandblasting equipment, but I do not have the time to disassemble and reassemble all of the tools.
I would be grateful for any suggestions you or the WoodCentral Family may be able to give me while I'm laid up with this broken foot.
Sincerely desperate,
David L. Frame Jr.
dframe01@hotmail.com
P.S.
If someone thinks sandblasting is the way to go,
I will buy some course media and get after it.
Re: Severe shop Moisture Problems
Not that hard *PICS*
>We have humidity problems too here in Georgia. Either tons of rain, or high hot humidity. Seems to be worse when tornados roll around which usually causes condensation to form on the cast iron that you can actually see and wipe off. And even with that I've not had too many issues in 13+ years.
By far the easiest way to deal with it is a 3M Scotch Brite pad and WD40. If it's really bad, I might place a random-orbit sander ontop of the pad. I've had to do that on some old machinery that I've purchased, but never on my tools I've had in the shop.
Then a coating of Johnson's Paste wax.
Simple, easy, reliable.
I've needed to use sand blasting equipment for steel frames that have been outside in the rain for decades, but for cast iron in a humid shop, it's overkill.
Happy Woodworking!
>I usually do what Mark does. WD-40, abrasive pads and wax. I usually use Renaissance wax.
When I rehabbed a bunch of tools for the church yard sale, I tried aluminum foil (dull side) and a little water. Just scrub. For light rust and oxidation, this method works great. You shred the foil, but who cares.
I have used Boeshield and it works well also.
del schisler
>I have use this on all my band saw - cabnet saw - jointer - chop saw - hegner scroll saw and leath rail's their must be some more item's bed's I have no rust and the bed's are slick Their are lot's of other thing's that work But i guess useser's choice this is mfd by boeing air craft so i think if it is good for them should work for me I guess i pay for their use ?? oh well thanks for reading here is the web page http://www.boeshield.com/
del schisler
>other pic can't show 2 at a time ??
Naval jelly then paste wax
jesse cloud
