drawer sizing advice
Bill Tindall
>I need to make a chest of drawers about 4 ' high. The drawer pattern will be 3 drawers side by side at the top followed by 2 side by side and then 1,1,1- 5 ranks of drawers high, for a total of 8 drawers. The question is how to size the drawer heights to be pleasing and not wind up the a ridiculously deep drawer at the bottom like many mathematical progressions lead to.
If you have such a unit in hand or picture in a book, or a flair for design, please advise.
Re: drawer sizing advice
>Before I knew any better I thought you were supposed to add the width of the stretcher to each successive drawer.
I have a Chest I made several years ago that is 45" tall. The top drawer is 4" deep, the stretchers are 1" wide. So, the Drawers are 4,5,6,7,and 8". There is a cove molding under the top and a base. Seems pleasant to me and the drawers are useful depths, or they would be if I put much of anything in the chest. The body of the chest is 34 1/2" wide and 18" deep. There is a hidden compartment under the top.
Obviously, you can play with this a bit. You could make the stretchers slightly wider or you could cheat the numbers a bit.
Is 8" ridiculously deep?
John Pappas
>Bill, this is how I did a chest of drawers.
Lets say you have 30 vertical inches for the drawer space.
Play with some ratios. For example this 30 inches is to be used in a ratio of 6:7:8:9:10. That is a total of 40 parts.
Top drawer: 6/40 x 30 = 4.5"
Next row 7/40 x 30 = 5.25"
Next 8/40 x 30 = 6."
Next 9/40 x 30 = 6.75"
Bottom 10/40x 30 = 7.5"
Total 30.
Different rations yield different heights. Try a couple others.
John
interesting approach
Bill Tindall
>I'll draw up an example for the task at hand.
Andrew F in Australia
>Hi Bill,
I've quickly sketched up something for you, assuming that the carcase has a plinth/kickrail of about 4" (sounded about right.)
The Arithmetical progression is one way out.
Visually, I like the logarithmic progression, but the bottom drawer at 12" high is a bit deep for my liking too.
Here's one way around this.
I'm assuming that the cabinet contains five drawer rails at 3/4" each and 4" plinth = 7.75" of available height used, making the available drawer space 40" (round down a bit - won't matter too much.)
Let's say the top drawers are 6.5" not 6" high
The second drawer is 6.5 plus 1 extra unit of height.
The third drawer is 6.5" plus 2 extra units of height
The fourth drawer is 6.5" plus 4 extra units of height.
The bottom drawer is 6.5" plus 8 extra units of height.
All up, the space needed for the drawers is 32.5" plus 15 units of height.
15 units of height = 7.5"
1 unit of height, therefore, = 0.5"
This makes the drawer heights as follows:
6.5 inches
7.0 inches
7.5 inches
8.5 inches
11 inches (still a smidgeon too deep.)
Repeat the maths, and eventually you'll get something to your liking.
Cheers,
Andrew
Another image without the text
Image showing 6.5" as the base unit
what I have learned so far
Bill Tindall
>1. There isn't any magic formula that "everyone" uses for determining drawer heights. It may be that there isn't a formula that any two people use! I have yet to encounter two progressions that are the same in my research so far. This discovery is a surprise.
2. The looks of the cabinet don't seem to be critically dependent on making this decision. This tentative hypothesis comes as a surprise to me. When I asked the question I presumed the progression of sizes seen in "quality work" would be constrained to but a few possibilities.
3. From what I have gleaned, in a 5 drawer high cabinet the first two ranks are(can be) the same height which reduces the problem to 4 heights to proportion.
4. The "book" formulas involving some mathematical progressions lead to ridiculously large bottom drawers in a 4 rank cabinet. An 8" drawer is acceptable but considered big in my mind. I don't know how anything bigger would be practically used.
5. I had never encountered the " depth of one above plus drawer divider thickness" approach for establishing the progression but it is certainly simple to use and leads to a practical progression of sizes. I will draw this progression up and see how it looks.
Thanks to all who offered assistance...........
Re: progressive drawer sizing article *LINK*
Henry (Raleigh, NC)
>Here's what I consider a wonderful article by Richard Jones in WoodCentral's Articles section. I have not read it in quite some time so I forget the progression details, but the picture shows progressive drawer sizes without massive bottom drawers.
Henry W
WC article - Richard Jones: Chest of Drawers
You could look at this *LINK*
Stephen Kirk in Quakertown PA
>George Walker has been putting out some information on traditional 18th C. design using Classical Orders. He has some DVDs available through Lie Nielsen (link attached). I haven't seen them, but I plan to. It might be of help to you.
George also has a pretty nice blog here:
http://georgewalkerdesign.wordpress.com/
I also recall and article in a recent Pop Wood discussing drawer graduation which I think was also by George:
http://www.popularwoodworking.com/articleabstract?aid=15205
Maybe this will help out.
http://www.lie-nielsen.com/catalog.php?grp=1320
