OT. Compression software - ZIP??
Jesper, Denmark
Jesper, Denmark
>Is my recollection faulty, or did not software like WinZIP and PKzip used to be Freeware?.
Paying for these with a US base is a bit too clutzy, so are there good alternatives out there?
Re: OT. Compression software - ZIP??
Re: OT. Compression software - ZIP?? *LINK*
John McGaw
>PeaZip works fine and is open-source free software. I handles all of the most popular compression formats.
http://peazip.sourceforge.net/
Dan Donaldson
>Not sure, but it seems to me that zip/unzip software is built into Windows, at least at a basic level.
Bill Howatt
>Yes it is - XP speaking but I think it is also in Vista and W7.
I have Peazip and find it good. Can't remember why but there was something I wanted to do and the Windows version was either too limited or a bit cumbersome.
Bill
del schisler
>pkzip is still free Make sure that you pick the one that is free This is the one i use
http://www.pkware.com/download-software
Jerry Nicholson
>An alternate (free) way of zipping and unzipping is to download the A43 file manager from the link. Like some other file managers, it treats a zipped file as a special kind of folder whose contents are visible and available even without unzipping. Powerdesk does the same thing but it costs money,.
Jerry
Free A43 File Manager
Also ....
Jerry Nicholson
>A43 does not modify the registry and can be uninstalled by simply deleting its folder.
Jerry
In Windows 7
Ed Beck
>In Windows 7, and I think very similar in Vista...
  1. Open the Windows Explorer and navigate to the folder you want to compress, or to the folder containing the files you want to compress.
  2. Select the files or folder(s) you want to compress.
  3. Right-click the items.
  4. Select "Send To... Compressed (zipped) Folder".
This will create a compressed folder with the files. The functionality is pretty basic, no password options, etc, but if all you want to do is compress some files then it works great.
Dave Paine
>Phil Katz had a long running legal battle with a company which was one of the first to publish "lossless" compression of files which used, if I recall the ARC file extension. The company name was SEA or SAE or something. They took Phil to court for imfringement. Phil lost. He then developed a superior compression algorithm, called the file extensions "ZIP" and declared this to be open source, essentially free for other companies to use.
Phil published a DOS version "PKZIP" which was free.
I believe WINZIP was published by someone else, using the PK ZIP algorithm and called it "WINZIP" which was not free.
I have a file manager PowerDesk which was a Windows application and replacement for Explorer. This also supports ZIP file extract/create/modify.
Lots of solutions in the market these days. Pick one which suits you.
I believe Phil Katz passed away some years ago.
The SEA/SAE legal "victory" was fleeting, rather a Pyrrhic victory. The won the battle, but lost the war. Who else remembers "arc" compression files these days?
Jesper, Denmark
Re:Thanks.
Jesper, Denmark
>As usual, a wealth of available information and willingness to share.
Thanks
