OT Solar Radiation Question
>Does anyone know of a site that tracks the solar radiation on a local basis?
I live just south of Richmond, VA. We have so much dreary weather or at least weather where there is little clear bright sunshine that I wonder if Solar heating would work effectively. Either for solar water heating or photo voltaic electricity.
Re: OT Solar Radiation Question
Dave Paine
>I have to see if I can find old rec.woodworking messages. In this newsgroups heyday they had a regular poster who built Solar heating panels in the midwest. I recall a message with a link to a site which showed statistics for average temperature, solar gain.
Big difference apparently in how you want to use solar.
I have a Solar hot water system, so this favours steeper angles. Solar heating, which heats air to circulate in the home favours less steep angles, frequently vertical to fit the house.
Solar panels for electric likely favour angle to match the lattitude.
My solar hot water system has been running since the mid-80's. I live in Eastern PA and so not a location people would consider sunny, but we get a lot of hot water from this system even in winter. Just need "some" sun.
Re: OT Solar Radiation Question *LINK*
John McGaw
>Is a single zip code area close enough for you? Then this might do the trick...
Solar Irradiance by Zip Code
Some sites to try
John T
>I had been doing some preliminary research into solar hot water in northern Maryland.
These sites may get you the answers you're looking for, or (like me) they'll just get you more confused....
Good luck!
-John-
General map
http://www.nrel.gov/gis/images/map_pv_national_lo-res.jpg
Photovoltaic watts estimator
http://rredc.nrel.gov/solar/codes_algs/PVWATTS/version1/
General specs by state
http://tonto.eia.doe.gov/state/
Peak Sun Hours
http://www.motherearthnews.com/Energy-Matters/Using-PV-Watts-Solar-Calculator.aspx
Doug Ring
>Hmm, I'm not so sure about the accuracy of the metrics from that site. I compared my house in mid-San Diego (less than 12 inches of rain per year) and my Dad's house north of San Francisco (more than 35 inches of rain per year), and the site showed that he receives only about 3% less average solar energy than I do. I would think that just the relative latitudes (~400 miles north/south) would account for more than that.
Joseph Mulherin, Sr.
>Barry, use this website to find out about wind generaters....
www.tangerie.com/products.
You could erect one of these and generate electricuty for heating and electricity with just a small area footage for installation.
Bill Turpin in WNC mountains
>Try the national Climatic Data center. Search solar.
NCDC
