Unisaw lubrication
Unisaw lubrication
Unisaw lubrication
Paul Blackwell
>A few days ago I posted a request for info on the procedure for changing the arbor bearings on a Unisaw. I pulled it apart yesterday, and after removing the belts, I found that the arbor pulley was slightly loose on the shaft. I tightened the set screws, put the belts back on and the saw runs quietly with no growling sounds. My question is, is it proper to lubricate the tilt and raising mechanisms with something like dry graphite? What do you use? Any info greatly appreciated. Thanks to all for the sources for the bearing change links.
Re: Unisaw lubrication
Delta technician recommendation
Bill Tindall
>I took a class on maintenance years ago and the instructor used Johnsons paste wax to lube the moving parts.
Re: Delta technician recommendation
Doug Reynolds
>Fine Woodworking had an entire article devoted to the subject of cleaning and lubrication of a cabinet saw. I don't have the issue number handy but, am sure a search would provide the issue number.
Fred Davis
>Delta is currently reccomending Dry Graphite or a light coating oc Lithuim grease.
I have used White Lithuim for a lot of different things like coating the plastic threads on a whole house water filter , so one could get it off to change the filter.
FredD
Brent Smith in Montreal
>I use spray graphite.
