reply to Mark Mandell about drivebelts on a Unisa
Fred Davis
>Hey Rick,
Everything I've read over the years seems to maintain the "rule" that you can't properly transmit more than a bit over 1hp on a single belt drive, and that's why multi-belt (and now poly-v belt) drives are used for 3-hp and up machines.
Is this incorrect
Yes Mark you are correct.
I suggested to the original poster that he contact the people at Delta for accurate information.
A couple of days ago this came up and I didn't have the time to contact Delta Technical service in Jackson , Mississippi. I emailed them and a Engineer by the name of Fred called this afternoon .
Fred said any saw motor over 1-1/2 HP needs Multiple belts , so the the Three and Five HP Unisaws have three pulleys for this reason.
Matched set belts are recommended for not only same size by cutting them from the same sleeve , but they maintain that size as the belts warm up and gradually wear evenly, which may not be the case with mixed sleeves or brands.
His follow up email was sent by his Secretary.
"Recently you requested personal assistance from our on-line support center. Below is a summary of your request and our response.
If this issue is not resolved to your satisfaction, you may reopen it within the next 5 days.
Thank you for allowing us to be of service to you.
To update or reply to this message:
1. Press your "Reply" button.
2. Place your cursor in the space indicated below.
3. Type your response.
4. Press your "Send" button.
Subject
why does Delta use three belts on their Unisaw ?
Discussion Thread
Response (Stephanie Riddick) 01/04/2010 05:18 PM
Dear Fred, we believe the following information addresses your inquiry.
To effectively transfer more than 1 � horse power through a belt and pulley system, a multi grove pulley must be used.
Thank you for allowing us the opportunity to serve you. If your question remains unresolved or if you require additional information please update this incident.
Sincerely,
Fred
Customer (Fred Davis) 01/01/2010 03:08 PM
This question has popped up on WC forum concerning the number of belts needed for a Unisaw.
A self described expert says they are not necessary and the only reason Delta uses a three belt pulley is and he says " folks would be scared if they didn't see that the machine had three belts".
My question is ,, is any of the above true?
Thank you for your attention.
Fred Davis
Question Reference #100101-000074
Product Level 1: Table Saws
Product Level 2: Stationary
Product Level 3: Unisaw
Category Level 1: Delta
Date Created: 01/01/2010 03:08 PM
Last Updated: 01/04/2010 05:18 PM
Status: Solved
