We value your privacy.
>Just do not understand what is wrong with me and the message board. I have to set my preference every time I look at the board to view current posts or to post or reply.
All the other boards I am fine on. I have deleted all cookies and wood central signed back in but nothing corrects the message board.
>I tried several times to get into the chatroom and windows says it is blocking the installation of ActiveX control because the request comes from a "unpublished source"
>Sounds like some kind of a security setting that is preventing the proper setting of the cookie.
For the chatroom, have you tried a different browser? I use Firefox and the chatroom seems to work fine. This make me wonder about your problem with an active x control because Firefox, by design, will not run active x. As far as I know, the chatroom is a JAVA application and should not need any active x controls for functionality.
I cannot tell for sure because I am running linux and the Firefox for linux is a little different from the Windows version, but not, I think, in that way.
>try this open up internet exployer go to tool drop down go to compatibility view settings open up and put a check mark in at the bottom in compatibility view ? Maybe this will help del
The dialogue box I get when I try to sing into the chat room goes from no activeX installed to when I try to install it says "Window has blocked this site because it has unsigned Publisher".
Probably BS
I just spent two hours going though evey suggested help fix and no luck . Time for Bed.
