We value your privacy.
>with the exception of lag bolts to connect the base to the top, or to connect a vise to the top, is there any reason to use lags or bolts on a workbench instead of glue? I'm only talking about the base (legs, stretchers, rails, feet).
I like glue (Titebond II or III) and prefer to not have metal someplace where glue will do as good or better job. Is there a reason that I should use bolts to join pieces together? I'm not planning on moving this bench.
>On mine, since I don't plan on disassembling the bench, I glued and wedge-tenoned (is that a word?) the legs and stretchers. The top is attached with bolts only because it may be removed at some point for flattening.
Bolts in legs and stretchers have a tendency to work loose with use; a wedged tenon will only come apart with a sledge hammer!
>My workbench is bolted together with carriage bolts and log bolts used on the top. I built this bench about 35 years ago and I can't recall ever having to tighten the bolts after initial assembly except when I dissembled it for a move.
>I built a similar bench about 35+ years ago. The end trestles are glued up, but are connected to the rails with bolts with nuts, not lag bolts. The bench top is located on the base with a couple of 1" dowels. Because of its weight, probably 200+ pounds, there was no need to glue, screw or lag bolt the top to the trestle base. My bench has served me well for over 35 years. I rest my case.
