PC router modifications
Virgil Johnson
>I have an old Porter cable router motor that I modified to make it a bit easier to maneuver. I bolted a milling machine to it. This solves the slow spindle speed problem and allows me to hold stock in the vise and use the mill table to move the stock accurately. The first setup was a locking rabbet for 8 small drawer fronts. The two small washer looking parts on the vise are space blocks for the Z axis that set the width of the locking grooves. The stop bolted to the left of vise locates the stock when I change parts.
Re: PC router modifications
Virgil Johnson
>Close up of the aluminum bracket. Fabrication time was around 2.5 hours. The next modification will be alter the bracket to allow me to hold the router horizontally.
Ed Beck
>I was expecting to see a Cisco wireless router or something decked out in a flame paint job :)
"I bolted a milling machine to it."
>I am reminded of the P-C radial arm accessory I just sold that mounted a 30-pound circular saw on 300 pounds of radial arm. Great tool; I just didn't have room for it.
Yours probably has a tool-to-accessory weight ratio that far exceeds that - maybe 8 pounds (tool) to 2,000-3,000 pounds (accessory milling machine)?
Brian in Brighton
>Your head doesn't tilt that way?
Most milling machines I've used have a head tilt for both forward and sideways tilt. Or, do you just not want to tram it again?
Nice job, BTW. I like that you made it good and stout.
Brian in Brighton
Virgil Johnson
>The head on the mill tilts but it is a pain and then I have to re tram. I could do angles easy enough but can't get horizontal easily. It will be much easier to make the router index.
