Apprenticeship update
Nathan
>Hello everyone. It�s been awhile since I posted an update on my apprenticeship. I missed a week due to illness and and another due to holiday travel.
Before Christmas, Master had us doing half-blind dovetails (see image below - I had to put two of them in clamps for the photo shoot because: (1) the boards were slightly cupped and (2) my dovetailing technique is crude at best). Since I did those, I have acquired a sliding T-bevel from Crown Tools, so my next dovetails should have more consistent angles.
More and more, we�ve been helping Master and the journeymen on �real work� that they�re doing. For example, Master set up the shaper with a power feeder and had me run moldings for some French doors in oak. We also rounded over a slew of tenons for those (the slot mortiser leaves rounded corners).
Last Tuesday, when I was the only apprentice in the shop. For hours I was up in the painting area helping one of the journeymen with a door that had been sprayed with some kind of gel stain (which goes on in a thick layer), but there were a bunch of small spots where the stain didn�t bond with the wood. Since it was impossible to get to them with a power sander, Master decided that the only way to fix it was to apply more coats with a brush. Anyway, there was a bunch of moldings that had been sprayed with the same stuff and they needed resanding and, in some cases, filling in with wood putty � so, while Master and the journeymen were dealing with the difficult job of fixing the stain on the door, I puttied and sanded all the moldings.
Things got more exciting the last two hours � Master called me downstairs and I found that he had set up an exercise for me on one of the benches: to make a cross-grain, tapered, stopped sliding dovetail joint by hand. That�s just like a stopped dado except the wall of the dado is angled on one side and the whole thing is tapered to enable it to be assembled easily. Well, needless to say that kind of joint was too much for me to do alone, but I did help him out while he made the joint. First he marked it out, then we used a sliding dovetail saw to make the sides, starting out at the end and pulling the saw towards me � one side was vertical and the other with a 7 degree slant. Then I chiseled out most of the waste and cleaned up the bottom with an �old woman�s tooth� plane. Then Master made the other side of the dovetail on a second piece of wood, using a sliding dovetail plane (the kind with a skewed blade and a nicker). He moved the plane along the end grain side of the board (which was about 2 feet wide), using his skill to make a taper that matched the taper he had laid out on the other piece. It was a joy to watch. Then he had me finish up the stopped end of the dovetail and then we dry fitted it. It was a tad loose, but serviceable.
All this has inspired me to get into the shop at home. So, for the past three or four days I�ve been working 8-10 hour days on a shelving unit for our basement storage area. First I made a detailed plan with all the measurements � that took a full day. Since it was my first time, it was a huge challenge for me. Then I spent two days cleaning up and rearranging the shop and prepping stock. When completed, the unit will accommodate fourteen banana boxes (7 x 2, going up floor-to-ceiling). My design calls for about 10 mortise and tenon joints, four of which are corner joints. I chose this because I haven�t gotten much practice with them yet, plus I have a slot mortiser. So, yesterday and today I�ve been cutting and fitting the joints. It�s been challenging, but a lot of fun and nice to see the project moving forward. I�d say I�m about 70% done with it.
Re: Apprenticeship update
You might not know this, Nathan, but
Bruce, a MN Galoot
>you are an inspiration. It is very inspiring to see the enthusiasm with which you tackle the new and allow those of us who've been doing this for a long time to feel that excited feeling of learning again. Thank you for posting.
Re: You might not know this, Nathan, but
Fred Davis
>Nathan ,
let me echo Bruce in saying your enthusiasm will serve you well.
The skill comes with practice and I see your getting plenty ;-))
FredD
I had some down time, but
Nathan
>Thanks, guys. I just wanted to let you know what was going on - I had some down time, but I'm back in the swing of it now.
It's 6:00 a.m. here now and in 20 minutes I'm leaving for another day at Master's cabinet shop. There's a feeling of anticipation, because I never know what's going to happen there - almost all of it is new for me. Plus I only go in on Tuesdays and Thursdays, so in the intervening days often projects I was working on or observing simply "disappear" (i.e. get completed and delivered to customers).
After reading and dreaming about woodworking for years, it feels good to be finally _doing_ it. As my yoga teacher once said, "you can't warm yourself before a picture of a fire."
