More mileage out of power-bits
Dale Lenz
Dale Lenz
>Has anyone had much luck doing something to make their #1 Phillips power-bits last longer? Can not seem to find my 3 sided file to clean up the four channels or the twisted profile.
I usually toss them and get another but sure do hate to toss a tool if I can get more mileage out of it.
TIA
Re: More mileage out of power-bits
Apex Brand
Grant in Iowa
>May I suggest you seek out a local industrial supplier that carries the Apex brand of driver bits.
I have found that they are far superior to all of the well known brands available at home centers.
Used in my impact driver to drive everything I need to I find they occasionally break when asked to drive a 3.5" deck screw without a pilot hole, but they never really wear out.
Also, I suggest you never use a #1 to drive a fastener that a #2 will fit.
FWIW,
Grant in Iowa
find out where the contractors shop and go there
>Go to Electrical supply houses. They carry high quality screw drivers. Sears also carries one with hardened metal tips.
You should be able to clean up the tip with a standard flat file. They have teeth on the sides as well and they are 90 degrees to each other. A V file is 60 degrees.
>I agree with those who say to buy the good ones. You will be pleased.
As for filing them, I am skeptical. The surfaces of the "wings" should be parallel to the axis of the shaft, not tapered. If they were tapered, they would cam out of the screws. The last ones I bought were not only perpendicular but also had "teeth" in the surfaces to grip the screws.
Incidentally, a good driver should fit the screw so well that the screw will stay on the driver if you hold it out horizontally. Use the right driver.
This is a great time to mention square drives.
Art Silva
Dale Lenz
Re: This is a great time to mention square drives.
Dale Lenz
>I think everyone for their valuable suggestions, will look for Apex brand Phillips drivers. Art, square drivers are nice, have a few, but I sell my work and most folks that get my flag cases, I assume, don't have square drivers. Gotta be customer friendly, you know, : ' >.
Dan Donaldson
>Send them a bit with the case. ;-)
Dale Lenz
Dale Lenz
>Any brand of tip you would suggest, : ' ).
>Dale, I would suggest one that fits. Find a driver that really snugs into the screw you are using and send them one. Whether its square drive or Phillips. Make the screws easy to install and remove without scarring them up. You could make a little storage place on the case for the driver and use a rare earth magnet to hold the bit.
OTOH, we don't really know which of these drivers will endure over the long haul. Might be better to develop a method of opening and closing the flag cases that does not require tools.
