Box Lids - For Martin McNamee
Nick Tuzzolino
>Martin: I like your use of the 1/16 three wing cutter to separate box lids. I normally saw my lids (we're talking jewelry boxes here) on the table saw, not going all the way through. I leave a minute portion of the wood just to hold it together (a la Doug Stowe's fine books and dvs on small boxes), and trim off the very fine remainder.
How do you do it to keep the lid rigid in the process? I know there are several ways, but I would like to know your's.
Thanks, Nick
Re: Box Lids - For Martin McNamee
Not Martin but
>Nick,
I've used a slot cutter as a saw as you envision. I used a 1/16 cutter on a mandrel that allows adjustable bearings and chose the bearing that left a "hair" uncut on the inside surface. After the routing is done, you slice the remainder with a single-edge razor blade and trim the tiny waste. IMHO will do better than a bandsaw so long as your joint line is within the router's elevation range
Tip: If you can't find or fit a bearing to leave the needed thin section, make a set of shims for the outside of the box on which your bearing will ride.
Re: Not Martin Either, but
>I made a bunch of boxes last years for Christmas gifts. I wanted a rabbet around the top of the box to allow the lid to interlock with the bottom of the box. Before I assembled them I cut a groove in the inside of the sides and then assembled the box. Note VERY carefully where the groove is. The depth of the groove is about half the thickness of the sides. Then to saw the top off you saw half way through from the outside exactly offset to one side of the groove. Once you separate the two you can clean up the edges of the saw cut with sand paper and the top will interlock with the bottom. You can also make the groove on the outside wider and intentionally leave a groove around the box and "celebrate" the joint.
I have also sawed the lids off boxes with a TS by making shims that fit into the saw cuts and taping the lid securely across the cuts. In other words, put a spacer in the joint and tape the lid back on as you cut it off. Then remove the tape after the last cut.
M. McNamee
>I first make a partial cut all around the perimeter. Then reset the fence and add a stop block so there is about 1/4 inch material uncut at each corner. Using a small hand saw, a few strokes and the lids are free.
THANKS to all.
Nick Tuzzolino
