Unifence differences
Chuck in ND
>I have a 30" Unifence that came with my Delta Contractor's table saw in 1995, this week I picked up another Unifence with a 30" rail. The castings of the two fence heads are different. Does anyone know if it's because it's a newer model or a different class of Unifence ? I'm also wondering if the Unifence was discontinued, a new one on the internet is fairly hard to find.
Re: Unifence differences
Doug Ridley
>Google up the Uni T Fence which is an upgrade and see if it is what you have.
Chuck in ND
>Hi Doug, I'm talking about the painted casting that locks to the rail. The one I've had since 1995 is a model number 34-915, the front adjusting screws are Alen head screws, and the casting is more squared off then the other Unifence model number U30, the front adjusting screws are plastic and much larger and have a hex bolt head. I like the looks of the U30 better then the 34-915, but I'm just wondering if the 34-915 is a better and or more durable adjusting method since they are mostly steel.
Doug Ridley
>I have no idea but I will look at mine after while and see if I can come up with anything.
Doug Ridley
>Look at Ebay. Both are on there. One is like mine, sort of blue-gray and the other is light gray and is numbered 400063120005 and it says it is a replacement. That's about all I know. Hope this helps.
Chuck in ND
>If it wasn't so cold out in the detached garage / shop I'd go out and take some pictures of the two fences. I guess what I'm looking for is someone thats had experience with both models. I'm also trying to figure out why Delta redesigned it or has two models.
Alan in Little Washington (NC)
>They changed the fence casting quite awhile ago. In addition to the shape the new one has large nylon alignment screws on the front. They also changed the front rail casting more recently. It is easier to attach to the table:
Chuck in ND
>Alan, the newer rail looks as if it has a bolt slot at the bottom side of the rail to bolt a power switch box to I'm guessing. Interesting, I wasn't aware of any rail changes over the years. Thankyou for shareing.
Chuck in ND
>Casting number 422-27-012-2004, this is the older style.
Chuck in ND
>Casting number 422-27-012-2004, this is the older style upside down.
Chuck in ND
>Casting number 422-27-012-2005, this is the newer style. Differences are, a new casting, the larger adjustment knobs on the front of the casting, a rubber coated lock down handle, Alen wrench storage, and the way that the cursor mounts.
Chuck in ND
>Casting number 422-27-012-2005, upside down.
Chuck in ND
>Now that I finally took some pictures of the two different styles so hopefully people can understand what I was originally trying to ask. You will notice that on the front of the older style fence that the two adjustment steel Alen head screws go through the casting and are fastened to a plastic coated square steel block with a C clip. On the newer style fence that adjustment has been replaced with a single piece plastic larger round threaded plug. My concern on the later style is that the large plastic plugs turn very easily by hand and that just slideing the fence along the rail could possibly turn the plug and throw the adjustment off. So, my question is to anyone who has ever had any length of experience with both fences, which would you prefer ? And why.
Chuck in ND
>A little trivia and to add to the confusion, the newer Unifence that I recently picked up came with the old style rail like the one that came with the older fence that I currently have on my saw, but it's silver in color instead of black. Possibly early production of the newer fence I'm guessing.
