That might work for really small things.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>But it would be pretty hard to come up with something to boil a couple of chair legs in.
You can save yourself a lot of work by finding some wood with that gradual bend grown in more easily than steaming.
You can make a steam chamber and boiler from almost anything. The rest is just plumbing in between.
Some pressure cookers have standard 1/4" NPT, pipe thread for the blow-out plug. This can be replaced with a flair fitting, and one of those crimped tubing lines like used behind space heaters to connect to the chamber. Pipe insulation will keep from loosing a lot of heat through it.
While you can use PVC with end caps for the chamber, I would consider making a plywood box with holes cut in the sides, where you only steam the part being bent, rather than the whole leg. While you are not likely to have any reverse bend outside of your planned bend, this take care of that potential problem, but it allows you to do more legs by cycling them through one at a time without having to open a chamber. You just pull one out, then insert another, or a plug as you run low.
If you are doing this outside in cold weather. I wrap chambers with several layers of packing foam to keep from loosing heat through the walls.
Also, I would have a length of aluminum foil ready to wrap around the bend area as quick is it comes out of the steam, until it is on the forum. This will stop evaporation and heat loss, giving you a little more time, which is in short supply when everything goes well, and means failure when unexpected glitches cause delay.
Here is a link to a free download book from Lee Valley. Everyone who plans to steam should get and read this several times before attempting it. While it sounds simple, there are many simple little things that will cause failure. Good luck
http://www.leevalley.com/wood/page.aspx?c=1&p=31161&cat=1,45866,45867&ap=1
