We value your privacy.
>The motor on my Unisaw went south. I'll either have it rebuilt or replace it. As I'll have it torn down I will replace the bearings on the arbor. My question is will the link belts work on the Unisaw? When I bought the used saw, I replaced them with Delta stock belts - the blade always stops in the same place - the belts I think have "memory" so I thought the link belts might resolve this problem. What is your experience or thoughts?
>Link belts work best on a contractor saw where the motor hangs by gravity, hence the memory factor on belts from hanging in the same spot over time. Because the motor isn't fixed, the memory factor creates a bounce resulting in slippage on the bounce. It tends to go away as the belt gets warmed up. The Unisaw with it's fixed motor tension doesn't have this issue. I spent ten years servicing Delta tools and would just buy 3 belts at the same time. With modern manufacturing the belts are consistent and there is no need to buy matched belts for higher prices.
Better than the link belts are cogged belts which do better on smaller diameter pulleys. They grip better than the Link belts and are cheaper.
Also the three belts are overkill from a day when that part of the Unisaw was over built. One belt is all you need. Proof of that is if you look at the industrial panel saw with 9 hp. One 3/8" wide belt and a fixed motor tension is typical and there is no problem bogging down.
Most of the probems are with contractor saws and folks trying to use combo blades to rip 8/4 maple. They thought they needed a 3 hp motor. Typically the problem is corrected with a less tooth rip blade and cogged belt.
The net is great but often more bad info is out there than good and most folks don't know how to tell the difference.
35 years in the commercial end of WW with 25 years of it doing machine repair and tuning machines.
>I put'em on my JET cab 8-9 years ago when I was going through the "bang-start" issue. They're fine but no better than quality "AX" cogged belts.
They do make a difference in single-belt drives. I use them on my band saw and jointer and they seem to run smoother; especially on the band saw (JET 18).
Everything I've read over the years seems to maintain the "rule" that you can't properly transmit more than a bit over 1hp on a single belt drive, and that's why multi-belt (and now poly-v belt) drives are used for 3-hp and up machines.
>I would guess that is old thinking. Why? Look at most modern vehicles--they use a single serpentine belt that runs a water pump, an alternator, an A/C compressor, a power steering pump and potentially a few other things. The A/C alone can account for several horsepower, an alternator would be 1-3 depending on the vehicle (about 1 HP per 60A), and the water pump is likely at least 1/4-1/2 HP (I'd have to look up flow rates and such for that). I have no idea what a power steering pump takes, but I was without on my small Mazda pickup last year (frozen tensioner pulley bearing, so I just pulled the belt), and it was VERY difficult to turn that wheel. That's no indication of what the pump is, but it is a high-pressure fluid pump, so you're probably looking at 1/2 HP or so. So when you start adding things up, you could be looking at 10 HP being transmitted through that single serpentine belt.
>...a reputable auto parts store. One where the counter guys know their stuff and can do more than enter your vehicle information into a computer. Usually, they'll have about 4 feet worth of parts catalogs lined up for ready access on their counters.
>True. But, like I said, you could be looking at 10 HP or more, not a mere 1-3 HP of a tablesaw. That number could be even significantly higher (more like 20-30 HP) in the case of a 15-passenger van with rear cooling. It takes quite a bit to cool off that much volume on a hot summer day! My ex-BIL once told me that they calculated the load on the engine of a tour bus from the A/C to be around 70 HP, but I don't know what kind of belt drive would be present.
>The people to ask are at Delta, as long as they advocate matched belts cut from a single sleeve, then why would you want to go in another undocumented direction ?
>Delta is not going to give you an alternative option. They will only give you the stock answer they have for the last 50 years. Advances in belt manufacturing makes it unnecessary to spend the extra for so called matched belts. Belts are made more consistent these days and cogged belts are far superior to standard v belts. OEM equipment for belts, blades is pretty low quality as a rule.
>Well Rick , just think how much you could save Delta by recccomending to them that rather then the expensive three belt pulley, just go for a single belt sheet metal job.
After all , bottom line engineering seems to be the way to go nowadays.
>I spent a number of years as an independent Delta Service Rep and have had that conversation with the Regional sales rep and other service techs at Delta. Going to one pulley would scare folks who would perceive it "cheapening" the Unisaw. I have worked on and set up many larger, high end panel saws and they only use one belt on 9 hp saws with no power or performance issues. PM went from three belts to two belts on the 66 years ago and they went through the same thing.
Hey... someone asked for advice and I gave my opinion based on professional hands on experience.
