How to tell "bad" finish?
John E in SC
>Recently tried to use some Bullseye shellac out of a can that was at least 9 months old. It looked fine in the can, and even seemed to brush on OK for the most part, but dried into a huge mess. It was very uneven, and brush strokes were very obvious. I was using this as a seal coat, so it wasn't a problem except causing lots of sanding, but I've not had that problem with shellac before. Is that what happens when shellac goes bad? Any way to tell this prior to applying it? (I know I should buy flakes and mix my own prior to use, but as I said, this was just for a sealer, and I had it already on hand.) My shop was fairly cool as well, probably in the 50's if that matters.
