cutting veneer miters
les winter
>I'm applying iron on veneer to some 3/4" plywood edges of a box. I'm looking for a method to trim the miters. Any input appreciated.
Happy New Year.
Les
Re: cutting veneer miters
Tony - Memphis
>I've used that stuff a couple of times for shop cabinets, but I didn't miter the corners. I just butted them together. I guess what Iowuld do is affix each edge just in the middle (leaving the pieces long and overlapping at the corners), then cut the miters so that I'm cutting the overlapping pieces at the corner at the same time. Then iron the rest down. That's a common way to do veneer miters (cutting them both at the same time). Use an exacto, veneer saw, etc., even a plane iron would work. Careful at the inner and outer ede - easy to split out there.
Tony
Re: cutting veneer mitres
Andrew F in Australia
>Hi Les,
Work from the back side of the veneer?, using a straight edge and a sharp single beveled knife.
To avoid a gap, overlay right over left if you're right handed. Practice on a bit of scrap and you'll see what I mean.
Cheers,
Andrew
jesse cloud
>What Andrew said, though I use a sharp chisel unless the veneer is too wide.
les winter
>thanks guys.
Les
