Wood finish
Wood finish
Wood finish
Jack Putnam
>I am making some table lamps from Aspen wood. I would to know if I can brush on shellac or some other kind of sealer with a satin finish to protect the bark and bare wood from peeling off later on.
I am using Aspen tree rounds. It's 2"thick by 10"in diamiter.
Thank You for any help you can give.
Re: Wood finish
Clint Searl
Re: Wood finish
Clint Searl
>No finish will alter the wood-bark relationship as things dry out. I'm currently making a lamp out of a piece of cherry limb, and the bark is clinging tightly after three years drying inside, with no peeling, even though there's an end to end split in the trunk.
Clint
Re: Wood finish
Re: Wood finish
>As Clint said, no surface finish will do what you're asking about. The durability of the bark/cambrium bond is dependent on the time of year the tree was felled and the amount of sap content. Until your samples are dry to EMC (final moisture content) you're just going to have to hope. Once dry, however, you can increase the "joint" strength by infusion of several resins. Very thin cryanoacrylate (buy at wood turner's supply) or thinned clear epoxy (thin with alcohol or by thinned resin) can penetrate/saturate the inner bark layers (especially if injected under pressure) and will set up strongly. There is a water-thin polyester resin, branded Polyall 2000, and several wood restoration resin products that may also do as well, although I haven't been very pleased with Polyall's performance for crack-filling on turnings.
Re: Wood finish
Re: Wood finish
Dave Paine
>As the other replies mention, a finish is not able to hold the bark to the wood if the two shrink at different rates.
If you want to effectively glue the bark to the wood, then covering the entire piece with epoxy may work. Likely to need a decent thickness, and you may not like the "bar top" effect, but this would minimize further moisture loss and hold the bark and wood together.
