Re: Resawing for drawer bottoms *LINK*
Fred Davis
>Doug,
for solid wood drawer bottoms I never resaw , only remove equal amounts from both sides with the Jointer and Planer until I have stock 3/8Th's" thick.
From the photos you can see the smaller drawer is about the dimensions of the one you describe.
I ran it parallel to the sides mostly for convenience.
The larger drawer out of the same piece of furniture is much larger in width and I ran it parallel to the front .
The bottoms are captured in a groove all way around.
The wood is Birch, a very stable wood and used for the all of the drawer sub- assembly.
For larger drawers like in a Chest of Drawers or Kitchen cabinets for that matter, I prefer a nice looking plain sliced Ash plywood panel unless the piece is meant to look traditional in every respect.
Then I glue up stock and plane it down and do as the pictures show.
The bottoms initially floated free until the Lacquer finish was applied and it looks like they are locked tight with that Lacquer with no movement.
The piece is four years old and looks like I just made it.
I have seldom let the back end of the bottom run though and secure it with slotted nails, though this is a traditional way to make drawers .
I have presently in the shop some European furniture made in the 1800's with hand cut dovetails and traditional drawer assembly and it looks like the drawers were made by a apprentice, sides cracked , dovetails split and anything not showing done rough.
Hope this helps you decide which way to go about a straight forward task without worrying about whether your violating any cardinal rule real or imagined about making drawers.
FredD
http://picasaweb.google.com/lh/photo/8_gnor1v9mfZUdAJF7UVlg?feat=directlink
