Jet 1442 vairable speed lock up
ben d.
>I have a jet 1442 that has had the same problem as Ken Kisling reported on his Jet 1236. The pulley froze up on the motor shaft, and the repair is to dissamblw both the drive and the driven clean and lub them both. I made me a board with a hole in it that would catch the washer behing the snap ring with one end on the head stock housing was able to compress the spring and no problem.
In the operators manual there is no mention of ever greaseing the sliding pulleys, although the motor shaft has a ball bearing to seal a grease hole that comes out the motor shaft that would lube that pulley if there as any means to do so. With all this said I wrote Jet and stated the same thing and and ask if they would bear the responsibility of the pulleys freezing up and what to do about the repair and who pays for the repair. The reply I received was that they are lubed for life and needed no futher lube.
I have sent an e-mail inquiry in Oct. Nov. And Dec. stating that they were now frozen up and sent a copy of the reply e-mail that they need no futher atention and I have not received a reply from any. I would say that they are ducking the problem and do not want to take responsibility. The very least they could do is to specify what lube but by doing so they would admit to an error which I suspect they will not do.
Like I was always taught if there is 2 pieces of metal running on anything that moves it needs to be greased. Another thing that I did was to go to a parts store and buy a top cog belt rather than the bottom cog belt they are using to replace the belt. I also filed out the belt grooves on the aluminum pulleys and the lathe quieted down considerably.
One would think that Jet would be more concerned about customer satisfaction than what they are doing lately.
My yearly rant.
ben d.
Re: Jet 1442 vairable speed lock up
>How old is your lathe? Having owned 3 lathes with the Reeves style drives and I've worked on some older school lathes with the same problem I can tell you that they do either freeze up or get very stiff over time. That's a fact of life for these drive systems.
Cleaning them is the very minimum. As far as lube goes I'm not sure. It sort of depends on the materials but I'm like you. I feel that some sort of lubrication is a must. I use one of the powedered lubes, graphite or molybdenum if I can. If the assembly is fairly well sealed I use a white lithium grease. I just sort of assume on this type of drive that I will have to disassemble and clean it every now and then.
>Good Morning Ben,
When I disassembled my 1236 I used a slight coating of white grease to cover the pulley shafts. It seemed to allow freer movement of the pulleys, but I don't know for how long. I didn't think of a cog belt, so I'll try one next time. I'll put up wirth the noise rather than try to groove the pulleys. That Reeves unit is a poor design, in my opinion, and I'll never buy another lathe which has one. This kind of crap is completely avoidable, but is a real good marketing gimmick for Jet. Otherwise, no complaints about the lathe.
George
>In it's day the Reeves drives was the way to go. Imagine having to change the belt to a different pulley every time you wanted to change speeds. Been there done that. You tend to turn at either too slow or too fast for much of the turning rather than change belts.
Then I changed to the Reeves drive. Great way to go. You could crank up the speed until the piece vibrated and then back down a little and turn. Cool. Did require a little work about once a year if you turn often.
Switched to DC motor. Really neat variable speed. Just turn a little dial. However it loses a lot of power at the slow speeds so you still had to change belts occasionally. Then one day the variable speed unit went out. I could not get it repaired locally and threw together a Bridge Diode unit so I could run the lathe but of course only had one speed. I did get the unit repaired but it was quite expensive. The Reeves drives usually don't have broken parts so you just take it apart and clean it'.
Step forward a few more years. Now I have the latest variable speed drive. A 3 phase motor with a Variable Frequency Drive. It has lots of power at the low end as well as high end. Is much quieter than the Reeves Drive. I'm worried about how much it will cost if either the motor or drive goes bad. Probably quite a bit.
Basically any way you go sooner or later you will have a problem with a lathe, be it bearings, bent spindle, motor or controller. That's why I went with the Powermatic. I feel that anything that breaks or goes bad can be replaced or rebuilt by aftermarket parts or a good machinist.
ben d.
>John''
The lathe is 3 years old I think and I run it a lot and this is not the first time for me to have to take it apart and clean up the drives. I agree white grease is not what to use and I had used it prior thinking it would not collect as much dust. This time I used a different grease and cannot remember the spec. but it is used in high torque universal joint applications where it is a must the grease will not be squezed out. I do not know about the dust pick up of this grease but so far has worked well and will just have to see how long it runs. I have a lot of hours on my lathe also and do maintain it,
Jet should put something in their op. manual to address this as I believe anyone that runs a lathe will find it to happen with the reeves drive.
May be a little noisy but shure beats changing the belt.
ben d.
Reeves Drive
>Thanks John,
I bow to your wisdom. I turn infrequently and inexpertly, and perhaps that is evident.
George
