Porter Cable Bradder
Thomas Norton
>I have a PC BN200A. I think it may need new O Rings. Today it just fired and the driver would not return. The manual says that if it is acting "sluggish" it needs new O Rings.
Has anyone worked on one of these? As I could use abit of advice.
Thanks!
Re: Porter Cable Bradder
Repair kit
>I have a couple P-C nailers, and when I bought them, it was recommended that I pick up one of their repair/rebuild kits so I wouldn't get caught short if/when they needed work. So far, I haven't needed the kits, but I don't use the guns that often, either. I'd suggest getting the appropriate kit for your nailer. They can't be that difficult to install.
Re: Repair kit
>I have a bunch of Senco nailers and staplers. I find oiling them is critical. I bought the oil they sell and put five drops into the air hose fitting occasionally. If you are not oiling yours regularly, try oiling it before anything else. On a bradder 3 or 4 drops might be enough.
Beyond that, get the rebuild kit.
Re: Repair kit
Thomas S Stockton
>Barry's right unless you have an oilless brad gun. They are pretty simple to rebuild and the kits are usually available at decent tool stores. My advice would be get the kit and take it apart laying the parts out in the order they came off and then putting it back together right then so you don't lose or forget something.
Usually to replace the o-rings all you need to do is pull the nose piece and undo the top of the cylinder. There is usually a spring under the cap so make sure it doesn't fly off. Push the piston out from the bottom and replace the o rings with the various parts in the kit and put back together again.
These things are pretty simple and are made to be fixed on the job site so there are not that many parts.
I think for most of them the only tools you would need are at most two allen wrenches and a small crescent wrench.
Tom
Re: Repair kit
Thomas Norton
>Thanks. I think I will order all the necessary O Rings. I do use the lube on a regular basis so that is not the issue.
Rick L
Re: Dental floss Repair kit
Rick L
>Back when I repaired air tools dental floss under an o-ring was the quick fix if we didn't have the o-ring in stock. Guns can be trickier to repair than you think.
