Jet JWL 1236 Lathe Variable Speed Problem
Ken Kisling
>My variable speed on my JWL 1236 Jet Lathe stopped functioning the other day. It appears that the drive belt only has tension on it on the lowest speed (550 rpm). When I move the variable speed handle to higher speeds the drive belt loses all tension. I can see that the wheel controlled by the variable speed handle does move towards the head stock when I move it to a higher speed but again there is no tension and the speed does Not increase. I believe this is a Reeves drive type of lathe. Thanks for any information.
