OT Leaky toilet Question, need help
>I have a toilet that has an odd (to me) flush valve/flapper. It is sort of a teeter totter thing. Its white hard plastic with a round end with rubber gasket and the other end is a cylinder about the size of a 35mm film canister. The cylinder has a hole in it and when you flush the water in it hold the flapper open momentarily until the water in it runs out. Then the flapper tips down and it seats. This is not the typical soft rubber flapper.
The problem is that the toilet runs occasionally and refills. Water is wasting, going down the drain. Turns out the flapper part is expensive and hard to come by at least in this end of the country. The first one lasted about 20 years. Replaced it a few months ago and it is leaking again.
Now I am trying to figure out exactly what the problem is. The seat for this is smooth white plastic and it feels and looks in good shape. The rubber gasket seems to be in good shape. The seal between the mechanism and the tank is some sort of soft rubber. It has deteriorated to the point that it leaves a very black inky stain on your finger if you touch it.
My question is, could it be leaking between the mechanism and the tank and not at the flapper? How can I tell? Is there a simple way to seal the hole for the flapper, fill the tank with water and wait? I was thinking about using a plumber's plug that expands into the opening, but I don't know if one comes in the right size and it might crack the plastic. Is this a job for Duct tape? Any suggestions? Any help would be appreciated. Wonder if I can change the entire mechanism?
