Reversing hide glue :-)
Virgil Johnson
>Soo....supposing you took your time during a glue up taking pains to make cawls(sp) to pull the dovetail joints together and after all of this one of them did not go together as planned. How do you reverse a dovetail joint that glued with hide glue and is cured for 4 hours? Steam?
Re: Reversing hide glue :-)
Lee Grindinger
Yah, steam but
Lee Grindinger
>Softening the glue that deep in a joint that will swell, thus tighten, with moisture might be really tough. I guess if it's a salvage operation you've nothing to lose but it's going to be a challenge. Steam the joint through and through and start wiggling it hoping it breaks free.
Larry Barrett
>Try a heat gun. Won't affect the joint as much and will soften the glue.
chuckbeck in cent il
>Or use Diff wallpaper remover and water about 5 parts water to 1 diff. Usually about 2 minutes the joint is lubed up enough to apply steady pressure. I use it too frequently on piano repairs.
chuckbeck
Worked.
Virgil Johnson
>The heat gun did the trick. I used two machinist jacks (screw jacks) to apply steady pressure to the inside while heating the joint from all sides. It took about an hour total. Luckily I did not have any glue joints on the side panels and this was the bottom joint.
Curious?
>So you wet and soak the joint apart with Diff and water? What then? How do you clean up the joint for reassembly and what glue do you use?
