home made taper shims
Tom Dunlap
>I know..shims are cheap at the borg...but I like getting the oink out of the pig and have my own.
The last time I made them I fabricated a jig that worked reasonably well. They came out being 5/16" x 6".
Does anyone have a link or description of theirs?
thanks
Tom
Re: home made taper shims
Fred Davis
>Tom,
your shim size is nearly identical to what I make , except I used a 7" length for no particular reason.
I cut a board 3/4" thick by about six inches wide and a foot long and cut the profile of the shim into a edge and then running the jig between the fence and blade, I hold stock precut to seven inch length and every time I cut a shim off the stock , I reverse the stock end for end and cut again,, thereby keeping the stock sides parallel.
If that makes you uncomfortable running it that way , put a handle on the jig, though I never have and have cut shims by the thousands.
FredD
Tom Dunlap
>You copied me! HAHAHA
Fred Davis
>GMTA ;-))
Jesper, Denmark
Jesper, Denmark
>A bundle of cedar shingles and yo have shims for the rest of your life.
Fred Davis
>Depends on what you are using the shims for.
Shingles are great for door hanging and not worth anything for installing hardwood moulding like big Crown for instance.
FredD
