Need (re)finishing help
John E in SC
>I'm working on trying to refinish the top of a sofa table that was ruined when someone turned over one of those plug-in air fresheners on top of it. Whatever was in the air freshener dissolved the finish, which was basically a satin black paint. I took it yesterday and sanded down the top so that it was smooth. It was pretty obvious that the air freshener "stuff" had soaked into the top, which appears to be MDF. I tried painting the top with and oil-based black enamel, but the area where the spill was has a very noticeable different sheen, and the paint over this area is still tacky, where the rest is dry. I'm assuming whatever has soaked into the wood is keeping the paint from drying. So the question is, what to do now? In retrospect, I should have tried sealing the top with shellac before painting. Would you try to sand it off, or just want longer for the paint to see if it will dry (only been overnight at this point)? If the paint eventually dries, would it be reasonable to apply a coat of shellac on top of that to seal, then paint again? I'm just not sure where to go at this point. Thanks!
Re: Need (re)finishing help
Jim DeLaney, Austintown, Ohio
>I'd remove the paint, wash/wipe the affected area with acetone or lacquer thinner, then coat it with dewaxed shellac - maybe several coats - then sand the shellac lightly before applying the black paint.
Jim D.
>I agree with Jim.
I would remove the failed paint, sand the top smooth, seal with shellac and repaint.
Back in the day, we used to make lacquered mirror frames with lights in them. People wanted the black lacquer effect on them. We found it easier to apply flat black lacquer paint and then clear coat them with compatible lacquer that was satin or low gloss and then buff the clear coat. If you do this, try it out on a scrap first to be sure the finishes are compatible.
Howard Acheson
>My first step would have been to use a chemical stripper and remove the existing finish. This would also have remove some or most of the chemicals in the air freshener liquid. Next step would be some light sanding followed by a shellac based undercoat such as Zinsser BIN. After the undercoat dries, see if the stained area is still grossly apparent. If not, apply one more coat of the Zinsser, let it dry and then apply your oil based paint. It may take a number of coats to fully and evenly cover the stained area.
a different approach
Bill Tindall
>I would strip what you put on back off. Then I would wash the offending area with solvent. Slosh it on and dab it back off, thereby removing some of the freshener chemicals. Then seal with oil based Kilz. Sand with 220 grit and the result will be a glass smooth surface upon which to apply the flat black. I use Kilz as a sealer/smoother for all interior wood surfaces to be painted, especially furniture.
Clint Searl
Re: a different approach
Clint Searl
>After all the stripping, scraping, washing, and sanding recommended in the previous posts, isolate the surface with a thin coat of water borne poly, and proceed to give it whatever black top you want. If that doesn't work, junk it.
Clint
this suggestion may not work
Bill Tindall
>Urethanes in general are particular about what they will adhere to. The chemicals in the freshener will undoubtedly be oil-like and not water soluble. Hence, there could be adhesion problems of the water based varnish over this oil-like deposit.
I think a much more reliable approach will be to seal with something designed to seal a wide variety of surfaces and deposits, and this would be Kilz or similar surface preparation products.
Clint Searl
Works for me
Clint Searl
>I try to avoid providing speculative advice.
Clint
Re: Yet another different approach...------WebKitF
Glenn Madsen---in SF Bay Area------WebKitFormBound
>If this were mine, and time were of any issue, I'd dig around in my wood bin, and find a piece of highly figured mdf, burl if possible, and make another top.
Fooling around with crap you can't identify, control or work with is not the fun part of woodworking. And you don't really have to match anything with a new top.
------WebKitFormBoundaryHx+OAVVtPgkhZeUW
