Testing Liquid hide glue.
Virgil Johnson
>I have a bottle of liquid hide glue that the expiration date on the bottle is 12/09. Trouble is that I don't know if the expiration is 12/1/09 or 12/31/09? Either its still good for three more days or has been bad for 26. The glue is stringy/tacky when a drop is pinched repeatedly between my finger and seems to be setting up on a test piece which I will try to break tomorrow. Any other ways to test this stuff? Thanks
Re: Testing Liquid hide glue.
>The finger test is the common test. I've used liquid hide glue that was over a year out of date and it worked reasonably well. I wouldn't sweat about a month.
Storage conditions are important though. If it has frozen - toss it.
It's still good.
Virgil Johnson
>Thanks for the feedback.I was wondering how other woodworkers tested the stuff cause I can't see us cheapskates tossing out the balance of an 11.00 bottle of glue unless we KNOW its bad. Our local stores do not stock the smaller bottles which I would prefer.
The sample I glued last night had 100% wood failure along a 4" edge joint.
the best test
Bill Tindall
>Using something like 2- 6 x 2 x 3/4" pieces of wood, glue a test block with a lap joint with the ends offset. After a day put one end of the assembly in a sturdy vise and bash the other end with a hammer. You should get nearly 100% wood failure if the glue is good.
numeric date rant and no expiry date?
GolfSteve in Calgary
>I absolutely detest the numeric date systems that proliferate around the world. What the heck date is 03/05/07? Pisses me off to no end. I work around the world and every country has their own stupid system. I've ran across actual usage of every possibly permutation of those three numbers. March 05, 2007...May 03, 2007...May 07, 2003, etc...
Recently I tried to buy some Titebond liquid hide glue. The bottles had no expiry date on them....I'm not sure why - is this something new for Titebond? Anyway I had the staff check when they last purchased hide glue, and it was two years ago, so I assumed it was past its expiry date.
Good luck, and please do not use numeric dates (without a legend) to help save my sanity,
Steven
Re: numeric date rant and no expiry date?
Howard Norman
>> What the heck date is 03/05/07?<
In the US that means March 5, 2007. If it means something else in another country I don't know.
How stupid is that????
>Howard, I think you are right, but who thought of that? The numbers are not in any logical order. MONTH being a larger unit of time than DAY but smaller than YEAR. So that puts the medium sized unit first, followed by the smallest, followed by the largest. DAY/MONTH/YEAR sure would make more sense.
I run into it all the time with coded dates on equipment. My favorite is the equipment that says "The first four digits of the Serial Number are the month and year of manufacture." Wouldn't it take less ink to just print "Manufactured May 2009"? Duh?
Rant off.
Re: How stupid is that????
Fred Davis
>Just to make it more fun Civilians put the month before the day whereas the Military and most goverment put the day before the month.
FredD
Howard Norman
>>I run into it all the time with coded dates on equipment. My favorite is the equipment that says "The first four digits of the Serial Number are the month and year of manufacture." Wouldn't it take less ink to just print "Manufactured May 2009"? Duh? <
Having spent about 40 years in manufacturing I understand the first four digits of a serial number being manufacturing date very well. What it does is makes sorting by manufacturing date easy and fast.
As far as Month,day,year, that is just the custom, logic has no bearing in a lot of things that we do in the English language and our society.
To me the whole subject is not worth getting into a tizzy about. Accept things as they are and worry about more important things in your life. At least that is the way I feel.
Jim DeLaney, Austintown, Ohio
>Yup! That's the way I write it, although it does elicit the occasional comment from the unknowing.
BTW, look at Ellis' date protocol in every message posted. He's in agreement with me.
Jim D.
Bill Howatt
>I'm with you Steve. Ambiguous dates should be banned somehow or the entire world should agree on one format (an even less likely somehow).
It probably wasn't so bad years ago when things used to be done on a more local basis. With world-wide trade it just isn't the case anymore.
Personally, I like the YYYY/MM/DD date format because it doesn't give a preference to the two more commonly used vague schemes MM/DD/YY or DD/MM/YY and it is logical big unit, smaller unit, smallest unit.
Bill
