Using Shortened Router Guide Bushings
Mark Salomon
>I'd like to rout a mortise using the walls of a dado (1/8--3/16in. deep) as the guide for a shortened PC bushing. Put another way, I have a solid case with dados for the top/bottom and shelves. I'd like to route through mortises most of the way through the sides using the dado itself to guide a router equipped with a shortened guide bearing (I'll come from the outside afterwords with a flush trim bit to eliminate the possibility of blowing out the mortise. Of course I'll also include stops to limit the length of the mortises.) Does anybody see a problem with using a guide that is so short??
