Trimming a workbench with dissimilar wood
Ed Beck
>I have a workbench top made from an old bowling alley lane. It�s hard rock maple and in the process of trimming it to size I cut through nails and have left behind some burn marks. Even if I were to sand the burn marks out the exposed nails would still be there, so I figure I need to trim it.
I�d like to trim it with jatoba (Brazilian cherry) because it�s a hard wood, will match the mahogany dots in the top of the table but is less expensive than mahogany. I�ve got a few questions about these woods growing and shrinking at different rates.
- How much should I worry about these two woods expanding and contracting at different rates?
- What kind of joint would you use?
- Since I�m building this in my freezing cold garage (average of about 40 degrees) about how much room would you leave for expansion? (The top is 92 �� x 38 1/2�)
- What should I be thinking about that I haven�t mentioned?
By the way, my wife got me a propane heater that I can use inside use for Christmas, it looks like it�s going to make life in the garage this winter much more bearable.
Thanks all,
