A55 Smoothing Plane
Bed/bath locksets
Bed/bath locksets
Bed/bath locksets
Randy Johnson
>Mom and dad built the house she now lives in around 1956 or 57. Recently the doorknob to her bedroom went belly up. It acted as though it was locked, but it was impossible to unlock it from the hole on the hallway side. It finally was opened with the aid of an eighteen inch pipe wrench.
Obviously, at that point there was nothing to do but replace it.
A quick trip to the local home center, a couple of good quality bed/bath doorknob sets, (replacing the other original to the house knob on another bedroom while I�m at it) and I was ready to have everything better than new. Oops!, the new knobs lack about an eighth of an inch or so of fitting the old hole in the door. Okay, the builder had a reputation for doing anything on the cheap he could get away with. A cheaper brand will probably work. Nope, it doesn�t.
I have a hard time believing that at sometime between the late fifties and 2009 the diameter of knob sets has changed so that today�s sets won�t fit older doors, but I can�t think of any other explanation. I�m sure that I�m not the first one to ever encounter this problem. How do I make the hole in the door larger so it will accept today�s locksets?
I think that if I use the cheaper brand (Kwikset) I can get away with simply drilling a hole on either side for the screws and doing a little chisel work. However, I would like to do a job I�m not ashamed of. All I can think of is turning a plug to fit the present hole, gluing it in place, and redrilling with the correct size hole saw. There has to be a better way.
Re: Bed/bath locksets
>I don't know about what the hole sizes used to be, so I can't help you there.
If the hole is too small, you could cut it out larger with a jig/saber saw and perhaps a rasp. Might be easier to carefully trim out the hole than to glue in a plug and redrill it.
If you have a drill press and a forstner bit you might be able to drill it out that way, but because of the size of the DP table, it might be a two man job.
BTDT
Dan Donaldson
>I have had that problem before. What I did was to get a hole saw of the proper size and drill a hole in a scrap of wood. I then clamped this scrap centered over the hole in the door and it acted as a guide to enlarge the hole to the proper size.
Dale Lenz
Re: Will a 1/2" larger hole be too big?
Dale Lenz
>Using a 1/4" rabbeting bit in the router on both side of the door's handle hole to some depth that the rabbeting bit still has wood to follow. Then chuck up a pilot bit and remove the last part of the remaining wood. Make sense?
Is this a great place or What?
>This is really a clever idea. Uses nothing but a piece of scrap and clamps and the bit/hole saw you needed anyway. Also allows you to shift the hole if you need to move the center slightly.
The Oops Arbor posted by Simon above is also a great idea, but does not allow you to shift the hole and you have to order it and put the job off until delivery.
Fred Davis
>Randy ,
The standard sizes of door lock holes is 2&1/8".
Doesn't matter who makes the lock or how much it costs.
Standard lock hole set backs for centers from the edge of the door are 2&3/8" ,2&3/4" and fairly rare 5" setbacks.
If your having trouble lining up the bolt assembly hole with the center of the lock hole , it is a lock you need to run a drill bit through the bolt hole, through the lock hole and drill out the far side of the lock hole until it accommodates the bolt assembly.
Check for all of this before you mutilate a existing hole that could be right and your looking at it wrong.
FredD
Re: BTDT
Randy Johnson
>I'm a little slower than usual today so I had to read your reply a couple of time before it clicked. It finally did.
Mom is in KY until Monday evening with the great-grandkids. Part of her Christmas present will be to come home to a working doorknob on her bedroom door. Thanks.
Why is such a thing important to someone who lives alone? Because at the age of 81, in a weak moment, she got a miniature schnauzer puppy. He�s a sweet little guy, but next to mom the most important thing in his life is stealing things out her bedroom. Currently she solved the problem with a barricade. A latchable door will be much better.
Re: maybe the "oops" arbor
Randy Johnson
>Neat tool but I'll go with Dan's suggestion. I already have a hole saw the right size but I couldn't figure out how to guide it.
Randy Johnson
>"The standard sizes of door lock holes is 2&1/8".
Doesn't matter who makes the lock or how much it costs."
Until this episode I would have agreed with you. Now I would modify that statement by substituting �should be� for �is�.
This isn�t a matter of how I�m looking at it. We are talking about whether or not one object - the lockset - will fit inside another object - the existing hole. It doesn�t/won�t, no how no way.
When I worked at the nursing home the administrator had, among her other quirks, an absolute paranoia about someone taking keys home with them if they were fired or left on bad terms. It happened a lot. As a result, I�ve probably installed at least a hundred replacement locksets of every description, from very expensive commercial grade to el cheapos. There were issues with setback, but the problem at mom�s house is the first time I have been unable to insert a new lockset in an existing hole.
Phil Joines Krum,Tx
>I ran into a lot of oversize locksets installed in some commercial buildings from the 60,s. I don't remember the size but they were about 1/4" too large.
Fred Davis
>Randy ,
it sounds like you have done enough to get the hang of it , hard to say without looking what the exact problem is , but the fix is easier then you may think.
If you don't want to change out the door , plug the hole , drill it the right size with the right setback and use a brass escutcheon goof plate to hide the original hole that you plugged if it shows.
If it doesn't , so much the better.
FredD
