Re: Saw Stop Question
Brian in Sandusky, OH
>I forget where I saw it, but I did see a demonstration where someone put a hot dog on a stick.
They then swung the hot dog into the blade.
Much faster of a rate than what a woodworker would ever do in normal operation.
It was still a tiny nick.
Consider this - the brake stops the blade in less than a thou of a second...literally.
The blade is stopped so fast that only two teeth make contact on a 40 tooth blade, before the blade is stopped and retracted
Go to the Sawstop website and look at the high speed videos.
Whether your hand is traveling at .5 feet per second, or 5 feet per second will make very very little difference.
Also - look again at the regular speed videos on the website.
They are feeding that 1/2 sheet stock faster than I feed 1/2 stock. And the thicker, the slower I feed.
