Finished my own Christmas present
Stephen Kirk in Quakertown, PA
>This is my version of Jefferson's 5 sided bookstand, which Roy Underhill featured on a show. I had wanted to do this, but found very little information on it. I met Row at the WWIA show back in October and he had the piece with him. We was kind enough to send me a measured drawing, which I used to construct the piece. The easels are all adjustable and fold down into a 12" cube. The box rotates on a center spindle.
This is constructed from red oak with walnut accents (the breadboard ends, ledges and clappers). The finish is 3 coats of garnet shellac followed by 2 coats of super blond shellac. The easels all have breadboard ends with through tenons. Lot of M&T to cut. The main box with the posts uses a single large dovetail on the end of each post. Lot of skills used in this one little project.
The toughest part turned out to be attaching the hinges. They are small, and use #4 brass screws. I ended up having to drill bigger pilot hole then chase that with a steel screw, then put in the brass. Still, the steel screws could snap off (had to move a hinge or two) and the brass screws stripped. I had to take a few easels off and trim them slightly as they were binding up when closed.
Fun project which just may wind up in the kitchen holding cookbooks. Now we can make 5 recipes at a time!
