I Give Up
I Give Up
I Give Up
Dustmaker Mike
>I guess I should just stop pretending I can make things from wood. I have been working on a few projects at the same time. I figure I only get a little while of shop time in a year and I had the last two weeks off with another two on the way I could get some stuff done. I started to make a few game tables I got the legs all done mortised and tapered no problem. The Aprons cut and fitted things looking good. I started to make the tops when the problem hit. I cut 1 1/4 strips of Walnut and Maple to make a checker board and inlay it on the top. All the strips cut and glued no problem. Cut some Alder to make the base of the checker boards do the glue up and sizing no problem. Attach all the glued up Walnut and Maple strips to make a checker board pattern no problem. Start to sand the top (checker board was 3/16"thick maybe a little thicker) using my Jet 16/32. Next thing I know I see the Alder show through the checker board pattern. The Alder was flat when I started but it bowed just enough to sand though the checker board. So along with the doll cradles I have finished exactly Nothing squat diddle nota no nothing. I am going to take a nap and maybe the elves will come in and finish a project for me(-;
Re: I Give Up
Naps are good
>Sometimes, when it's not working out, it's time to leave the shop for a bit, and return when you're feeling energetic. Naps are one approach.
Re: I Give Up
Re: It happens to the best of us
Chuck in ND
>This is why I get so frustrated at people that want something, and then make the comment that it should be easy. Yeah, it's easy, but planning and setup can take alot of time, and even then screwups happen. It's easy to make a mistake, is whats easy about it.
