Cutting board
Cutting board
Cutting board
>A gift for my BIL. Cherry and walnut from the family farm. End grain about 21 by 14"
Re: Cutting board
New Camo Pattern
GolfSteve in Calgary
>Reminds me of the British Army's new camoflauge pattern :-) Certainly eye-catching.
I like the pattern and the edging.
Cheers,
Steven
Re: Cutting board
Re: New Camo Pattern
>Thanks, Its actually a brick pattern, but the camera did not catch that. Its the mix of sap and heart in the cherry that creates what you see.
Re: Cutting board
Re: Cutting board
Hal Langerud
>Amazing.
How in the world did you manage to get every piece so tight fitting?
Hal (On the York River in VA)
Re: Cutting board
Re: Cutting board
>Craftsmanship???
Really thick glue????
Lucky???
Bought wood that was already fitted???
Actually, I have made a bunch of these. Try to do good accurate prep, nicely square pieces, run through a planer to make good crisp surface. Glue up the strips long grain. If the price will fit through the planer, plane both sides flat. You could stop there and have a side grain board. Any number of woods will work and any combination that is pleasing to the eye. Then I cross cut the board into about 1 1/2" strips and keep them in order. Stand them on end and flip every other one end for end to create the brick pattern and break up the joints. Some times you have to side slip them back and forth to get the pattern to work. I line them up, draw a couple of lines from end to end and put in two or three rows of biscuits, as much for alignment as anything. Slather the edges with glue and clamp them up. Rip off the raged edges and run them through the Performax to clean up and level the surface. This one and its brother that I did not post were too wide for my planer, so the Performax leveled the strips both ways. I made them before I had the Performax. Sanding them level with a belt sander was harder but not that bad. Used Titebond 111 for a water proof glue. I have made them with the center dished out or depressed about a 1/4 inch on purpose on one side and the other side flat. The dished side is for meat, the juices drain to the center. Blood groves just take up room and a hard to sand smooth and to keep clean. The flat die is for veggies and pastries.
Re: Cutting board
Re: Cutting board
Hal Langerud
>Thanks for the description of what you went through.
I'm afraid I still don't exactly understand. Though I printed the picture and your explanation and will study them more. Not that I plan on trying to duplicate your work, but just out shear interest.
"Dishing" out one side is something I'd never heard of nor seen, but seems like an excellent idea.
