Help Locating Black Epoxy
>Good Afternoon Friends,
My best friend Charlie and I are fabricating a table top from a slab of black walnut which I ripped, resawed, planed and jointed. It has some beautiful bookmatched grain, some portions contain areas of significant character/defects which must be filled and leveled. Norm used a liquid epoxy on mesquite, as I recall. We'd like to use something identical or similar but have not been able to find it at Woodcraft or the box stored. I don't even know what its called. Can somebody tell me what to ask for, and where it is sold, or a mail order source? Thanks,
George
Re: Help Locating Black Epoxy
Howdy I used
Dustmaker Mike
>System three epoxy and some black powdered tint I got from Woodcraft. I used the black powder to color the epoxy and it worked great for me. You even tint it a little closer to the color of the Walnut if you play with it a little.
DouginDenver
>I imagine there is such a thing, but I can tell you what I did once for what it's worth. I cracked some black marble in a firplace surround, so I took ordinary epoxy from the hardware store in the two tubes and mixed it with some black unsanded grout - the real fine stuff - worked like a charm. It will make it very black, so if that's what you are looking for, that's an option. You could even mix in some brown grout if you want it less black.
GalenV in Iowa
>Craft Supplies catalog 2009 page 74 has black inlace 024-0107 in 8 oz. can.
Chad Pearson
>I use black toner out of the laser printer cartridge. It takes a very small amount to make the Epoxy plenty black.
>George, I did the same thing all these guys did. I bought System Three from Woodcraft because I had been struggling with the borg stuff. I was gluing the dovetails on the walnut toy box I made for my Niece and I was afraid the glue was going to be amber or cream colored. I added some powdered "dark Walnut" stain out of a Mohawk furniture kit I have had since we were both younger men. A tiny (really tiny) amount turned it dark brown. It did a great job and it got nice and hard. It was much more liquid than it appeared so you might want to get some filler for it, like the colloidal silica. I have no experience with that and I under stand it will float on the breeze, so wear a mask and don't inhale it. Mine looked thick and gooey, but drained out of a joint that was about 1/100". Dam it up good.
Another thought would be to celebrate the defects. My son made a table for his mother (my X) and the top was deodora cedar. We took some brass screws and filed them away to nothing. Packed the defects with brass filings and solidified them with epoxy or CA. Looked great. Started to use my former wedding ring, but that might have been a bit crass.
CARBON BLACK!
Art Silva
>George I mix black shoe dye to make black epoxy. However there is a good product called Inlace that comes in black. I've used a lot of it. You can get it at Woodcraft but I buy mine from the link below.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Hi Col. You can mix lots of things with epoxy to change its color, but I usually just use some sanding dust from the bag on my belt sander from whatever wood I am using.
However, if it is just straight walnut dust, this tends to come out too dark, so I usually mix about half colloidal silica, or maybe even dust from a lighter wood.
If you were thinking of just flooding the surface with clear, you had better really heat the wood up first, so as the wood cools, it will draw the epoxy in, as the air inside the cells contracts. Otherwise, any air in the wood will bubble up in the slow setting epoxy.
Jesper, Denmark
Re: Easy, Graphite powder....
Jesper, Denmark
>Mix a little graphite powder into the epoxy. It does not take much.
Note that the result will not be transparent, but if you need to fill in voids etc., it works.
Clubmaker Shafting Epoxy -1/2 Pint Black  *LINK*
David Barnett - SW FL Gulf Coast
Re: Heck ColonelI
Larry Clinton At Frankfort (Central)., Indiana
>I just finished up a real oddball door sill for a friend - (floor in one room slanted and the new room didn't). I had to use an old piece of oak that had some cracks and knots - I mixed up some of the Wally world 2 part 1 hour epoxy that comes in the proportioning dispenser - then added some artist oil paint that I blended to get the color I wanted (Dark brown). I wasn't sure it would cure ok with the oil but was hard within the hour and sanded and finished great. In the past on a piece of woodwork in my sons house, I had a large know partially missing on a beautiful white oak board. I "painted the bottom of the knot hole with India ink - let it dry and used the same type of clear epoxy to fill the void. After sanding and shellac, the epoxy looked like a pool of water with a black bottom. My son use the board over the entry to the kitchen as he and his wife both loved the appearance. I think you can use just about anything you like to color the epoxy and it will work out very well. Don't know if it will affect the strength of the bond but in these applications it really isn't a factor. Have a Merry Christmas and a Happy New Year George.
