Porter Cable ROS Question
Thomas Norton
>I have noticed recently that my ROS has been getting hard to handle. It seems to "have amind of it's own". It never used to do this.
Any Ideas?
Thanks
Thomas Norton
Any Ideas?
Thanks
Re: Porter Cable ROS Question
>Good Evening Tom,
I'm nort sure what you meqan by it "having a mind of its own". I've owned two P+C 333 sanders which are 5". I still have my first: it is a good tool. The other one over spun, and replacement of the band used to control the spin speed was ineffective, and it continued to over spin despite my replacing the band several times. Secondly, I noticed the tool was vibrating much more than my other P+C 333, and I attributed that to a slightly bent shaft. I can't remember dropping it, but it was a "blem" when I bought it. I threw it away rather than fool with it anymore, which was one of my more intelligent decisions. They are great when they work.--like bowels.
George
>Like the Colonial, I have two of those. I like them. I wore out the first one and was in the middle of a job so I bought a replacement and then ordered parts and fixed the old one.
The main lower bearing failed in mine. It also spit the speed control band the Colonial mentioned. Its been a while, so I don't remember the exact order of events but I suspect the bearing was going, causing it to ruin the band. The local bearing did not fit, it should have, but it was mismanufactured. Ordered replacement parts including the lower platen or whatever it is. I think I cracked it either trying to get the last bit of life out of the old bearing or fighting with the mismanufactured bearing. I remember there was an Oh S**t! moment, so I think I broke something.
The end result was I suspect your lower main bearing and the speed control band. OTOH, did you drop it and bend the shaft?
