Tear Out I am hating it
Dustmaker Mike
>I am making a couple of doll cradles for my Granddaughters. I am using some air dried maple I have had for the last 6 years. I have never seen so much tear out around mortises ever. I used my Jet mortiser to cut the threw mortises and made sure the chisel was sharp. I had a backer board on the bottom to help stop this but it did not work so well. Oh well now I have to figure out how to repair a few split outs and a lot of little tear out. Maybe just round over all the mortises on both sides and see how that looks.
Re: Tear Out I am hating it
Suggestions
>1. Run the mortiser from the "show" side so that the joint's shoulder will hide any tear.
2. Set your cutter to just pierce the "bottom" side of the stock, then finish the cuts with a bench chisel rather than pushing through with the mortiser.
3. Pay special attention to how parallel the machine's chisel is to the edges of the stock and the fence plus never take more that a 3/4 bite so that the previous cut acts as a guide.
4. Use tear-out preventer on the bottom surface. (Yeah, water works as well here as it does on the planer.)
Question: Are you clamping your workpiece down against the backer? If not, the drill bit will tend to "jack" them apart negating the effect of the backer and allowing the splits.
Don't go all the way through
>Like Mark suggested, mortise to within an eighth of an inch or so of the other side and then clamp the piece to a solid backer board and chisel out the remainder, endgrain cuts first. Hollow chisels are a very bad bet for clean through mortises.
Thanks I will try it next time
Dustmaker Mike
>all four of these pieces are already cut. I think I can clean them up with a file and bevel the edges to make it easier for the sides to slide into them. I walked away for a little while to rethink how to attack my learning opportunities.
Re: Thanks I will try it next time
>Good suggestions so far.
I was wondering if you could make the pieces an 1/8 or 1/4" too wide, mortise through and let the other side blow out. Then rip it down to size or run it over the jointer. Or you could mortise nearly through and rip the side off.
