Fitting Dovetails with Leigh Jig questions
>I have a Leigh jig. I know the stock is supposed to be accurately milled but recently I made a toy bow out of some 15" wide boards. I had to "dress" the walnut with my Performax because it was too wide for my planer. I found the Performax makes on side one or two hundredths thicker than the other. So, does that affect the fit of the dovetails?
Re: Fitting Dovetails with Leigh Jig questions
doug f, san clemente, ca
>Yeah, Barry, I think you're going to find it severely affects the fit of your dovetails.
You should be able to adjust the Performax so that the difference in the two sides is in the 1-3 thousandths rather that hundreds. I have a Perfomax 22-44 that I've adjusted to 0.002 difference in the two ends. It's not hard, just very tedious; beer helps.
It can also help to swap your boards end for end at the same setting and running them through that way. Any difference would even out.
Have fun with your project.
Doug
Dick Coers
>Oh man, 2 hundreths is a bunch. I assume you are cutting through dovetails? Both those cuts are done on the front of the fixture. The tails shouldn't care, but won't the pins be bigger? At least some of them are going to be thicker. It is going to make some of the pins end up flush, and others stick out. I think getting it all flushed up, and keeping it square, is going to be the tough part. But I think since it is all registerd off one face, the fit of the pins in the tails will be okay. Wouldn't it be easier to tune up the Performax?
Re: No problem
ThomD
>You shouldn't notice much problem if one side is flat. put that side along the back of the jig, and use the flex in the clamping bar to accomodate the front. Or force the panel flat by the same means. Just so long as the inside corner of the joint is flat during cutting, and later during glue up, the fit will be perfect. 2 thou is a lot to have as a distortion in the geometry of the cut parts, but not much where the treaking of a 15" wide part is concerned, with clamps.
Also, you can flatten just the inside of the joint, to the height of the metal in the jig body, a few swipes with a plane, and get back to zero with the fit in the jig. Of course this can lead to chasing the parts and fit for the rest of a project. probably not a big deal in a blanket chest, but it could be a big time waster in a complex project.
This is challenging my visualization skills...
>I'm trying to figure out the effect. Lets say all the boards are 15" wide and 2/100" thicker on one side than the other.
These are through dovetails. The boards rotate through the jig so that on each one, the thick edge is against the stops on one end and then the thin one goes to the stop on the other end.
It seems that they come out so that they stick progressively further through the stock. If they are flush on the thick edge, they protrude 2/100" on the thin edge. (I used a belt sander to clean that up.)
So, the two questions seem to be: Does this make the dovetails get progressively tighter/looser across the boards? And, does the box come out "Twisted", with two high corners and two low corners? Or, does rotating the stock throguh the jig somehow cancel the effect?
One more thought/question
>When I set up the DT's the book said to eyeball the first and last finger. I set one side at about an 1/8" and the other at about a 1/4". Don't ask me why, just seemed like the thing to do at the time. I thought the process would compensate for the difference. Is This why the box was slightly wampas? (Wompass being a lesser degree than cattywampus.) I planed of the two high corners on each side.
Adjusting the Performax question?
>Doug, My 16/32 Performax is about fifteen years old. I bought it used about five years ago. It worked so well,I left it alone, Now it seems to have gotten further off than I thought it was. I thought you could set it parallel to the table or so that the open ended was slightly thicker for sanding stock that was double the width of the drum, so that there would be a very slight crown in the piece rather than some sort of "trail" or sander mark down the middle.
How much trouble was it to set up yours? Any advice?
Well,...
>To be honest, yes, it's a pain in the posterior.
Believe it or not, the instruction manual actually works. UNPLUG THE MACHINE!! Take a block about 3x3x2 and place it on the conveyor belt. Take the paper off the drum. Start at the motor end of the drum and run it down so it just kisses the block, then check the other end for the difference. Then start adjusting the bolts that adjust the drum either up or down, tightening or loosening until the drum just kisses the block on each end.
This takes a lot of tightening, checking and then adjusting the other way. It's tedious, but it will eventually work.
Once you get it correct, make sure the bolts are tight and be careful about banging the arm either up or down.
Like I said, beer helps.
Have a wonderful Christmas!
Doug
Re: One more thought/question
Larry Clinton At Frankfort (Central)., Indiana
>Barry, I have the D4 Jig. It is hard to visualize, but I believe the widest portion of the pins would remain the same and the tails would be the same width at the widest point. Therefore the pins should fit tightly across the whole joint. Location of the pins and tails with the jig has no effect on the tightness or squareness of the joint. However I had a couple of problems when I first started using the jig with progressively looser pins across a joint. I found the board was moving, "slipping" in the clamp causing the pins to be smaller as the board moved. I also had some problems with the top plate flexing "down" as I routed the parts causing the joint to be less than perfectly square. I made a new "spacer board" and re-aligned the jig and that problem went away. As to the board slipping - the new jigs have the front plate serrated or roughened to prevent slippage. So far I have just made sure the clamps are very - very tight and have been successful. I intend to install some self adhesive fine sandpaper across the plate before I do my next job. Provided these issues are not your problem, the taper across the board would cause the inside of the joint to be square with all the error showing up on the outside as out of square with some of the pins not completely filling the tail and some pins protruding beyond the surface. I don't have a drum sander - do all my surfacing on my 20" planer with byrd head so don't have the thickness issue.
>Thanks.
I had one socket that was off by about an eighth of an inch. Now I think I know what happened, The board slipped. It was one out of all of them and I did not know it until I put them together. Luckily, it was the one closest tot he edge of the board and I just made that the bottom of the box and the base covered it. Funny, it had not occurred to me that the board slipped. I was looking at the fingers and all the other bits and pieces.
Good idea about the sand paper. I was trying to be careful not to over crank those cam's. Maybe I should have put a little more pressure on them.
It seems to me that if the boards are cut square, the box should come out "level". The jig indexes off the ends of the board and the thickness should not matter except that the tails will protrude more or less. I think??? I use this thing just often enough to forget everything I thought I knew in between uses.
Use adhesive-backed sandpaper on the.............
Art Silva
>clamping bars.
