Re: Dust buildup in Dewalt DW735 planer
Dale Critchlow
>Sorry, I didn't get back earlier about the dust buildup in my planer.
In answer to the question of what dust collector I use; I have a 5HP cyclone which moves a lot of air.
The fan is working fine. If I take off the hose, it blows chips across the room.
I have taken the hood off several times and cleaned it thoroughly. I can't see any obstructions. I have to clean it out after about 30 minutes of work. The dust gets into the gears that drive the lift mechanism and I have to dig that out with a screwdriver.
I may try installing foam insulation under the hood. The type which has a sticky side like you use to weatherproof doors.
Any more suggestions are very welcome!
Thanks,
Dale
