We value your privacy.
I'm getting ready to slice some veneers from a piece of spalted hackberry that I received several months ago for my birthday.
It measures 2'x3.5"x7/8". I want to use it for some drawer fronts on a small tool chest I'm putting together.
Any thoughts on how many pieces of veneer I should be able to get out of this single piece. I'll set up my band saw with a new Wood Slicer blade if that matters.
I'm new to slicing veneers so this will be a big factor.
>I like to end up with 3/32 or slightly less after glueup and sanding. One way to get a slightly better yeild is to glue up a sandwich of two backer veneers, two center pieces (solid wood?), and a piece of the hackberry. After that is dry, then resaw it thin, getting great bookmatching with minimal waste. You will have a thick sandwich to work with, not thin spalted pieces until you get the scraping/sanding stage.
>Victor, I am no expert on resawing, but what I did was set then fence to take the thinnest slice I could get reliably. Probably about a 1/16". Take off a slice. Run the sliced face through the Drum sander to clean up the saw marks, take another slice, repeat. Gluing the hackberry to another board would give you a chance to slice it right down to nothing. (I usually end up with a piece that is less than 1/4" and use that as a panel in a box or something.)
Then I sand my stock to a known thickness and laminate the veneer to it. I put common non spalted veneer on the back side for balance. When I do the glue up, I glue the sanded face down and then run the piece through the sander to sand off the saw marks.
I have never used a wood slicer or any other premium blade. If I did, maybe I would not have to worry about sanding off the saw marks and could glue the sawed face down.
I made veneer as thin as 1/50". Sawed it as thin as I dared, double stick taped it to a piece of melamine and sanded it very thin. Did it as part of a lamp shade so the light would shine through. Turned out to be fairly easy. Birds Eye maple and wormy holly.
>is to resaw at about 1/8" and thickness down to about 1/10" (roughly the 3/32 that Dick mentioned) for layup. One of the advantages of resawn (as opposed to peeled) veneer is that the sawn veneer is thicker so you can plane or sand it without worrying about going through, plus it will stand up to digs and dings much better and the edges won't chip or wear off as easily. Another advantage is that there won't be any of the micro-checks that you often get with peeled veneers.
So, my suggestion is to try to get four pieces from your 7/8" blank; five is possible but stretching it. Joint the sawn surface of the blank after each slice, but don't waste any more material than you need to to get back to a clean surface.
I haven't tried Dick's method and don't really visualize what he's suggesting, but it might be worth looking into. Just remember that thicker is better.
