Small problem I hope
Dustmaker Mike
>I was planing some Maple to make two doll cradles when I noticed the planer was shooting chips from under the hood. I had just emptied my little 650 dust collector about an half hour before so I figured it was full again. Well full is an understatement. The chips go half way up the top bag. My question is how can I empty this with out making a very large mess? I stopped for the night because when I do stupid stuff like this I know it is time to stop(-;
Re: Small problem I hope
John Veerkamp, Western Mo
>I just did the same thing with my DC about 2 weeks ago. I'm sorry to tell you that I know of no way around the big mess. Planners do make a lot of shavings don't they.
John
GalenV in Iowa
>Can you slide a large leaf collection plastic bag up over the lower bag and hold the top out away from the unit and remove the unit bag. Seems like it may help catch what falls down out of the upper bag too.
That is while wearing a dust mask!
Never tried it as my little Delta it is where I can see the bag getting full.
Glenn Madsen---in SF Bay Area
>'Tis the season. I just did this a couple of weeks ago.
I solved the problem with a second dust collector, and stuck a hose in under the top bag edge, and sucked out about 40 gallons of stuff. The chips & dust in the top bag was now down below the rim of the (impeller area?) and I was able to pull out the very full lower bag, and empty it where it belonged. Then clean up the second DC. Then clean out the drop box can, behind and under the lathe, the backup into the Unisaw, the small DC again, and the drop box again.
Only took two hours. Or three. I forget.
Merry Christmas!
Doug Ridley
>Get your wife to do it.
I guess I am in good company
Dustmaker Mike
>I am also glad to see I am not the only one to have done this(-; I am going to try with my shop vac this morning to see if I can get most of the stuff out of the top bag. I have a bigger Dust collector but it is not hooked up right now, I have to bust a hole in the wall and run 220 to it. Some day. Thanks I will put a large bag under the bottom bag to see if that helps.
My top bag blew off when it got toooo full!!!
Frank on Chestnut Hill
Even worse......
>Mine is outside the shop in a little outdoor closet. Somebody gave me so over sized bags. Without thinking it trough, I put one on the machine. One corner of the bag slide off the platform and touched the floor. Rain blew in. Water soaked into the shavings. The bag expanded like a big fat belly and was larger than the frame with bulges on all sides. Anybody want to take a stab at what a huge bag of soaking wet sawdust and shavings weighs? I have no idea, but its a LOT. It might have been better if I had caught it before it filled into the top bag also.
I bought a trash can to put the bottom bag into. Its about four inches short of the ring so I can tell when the bag is full, If I go out there and look. It works great at containing the diameter of the bag and keeping its toes out of the water. And it's much easier to handle than a bag alone.
Glad to know I am not completely alone. Wish I had a good answer for you. Also wish somebody made a good simple "bag full" alarm.
Success with very little mess
Dustmaker Mike
>Well I got it done in about 20 minutes. I put a large trash bag around the bottom bag just in case. I opened the top bag just enough to get my shop vac hose in it. I then used my shop vac to clean out the area between the two bags then closed off the top bag with a heavy rubber band I took it off still 3/4 full. I then cleaned out the rest of the space until I was below the rim of the bottom bag and took it off. Went and dumped them both in the grass clippings I have been piling up emptied the Shop vac in to the large trash bag all done(-; PS use a filter on the shop vac.
Re: Success with very little mess
jerryburns
>I put a trash can in front of my DC and keep an eye on that I too filled up the top bag and made a mess empting it out
Bill White
>I've just gotta say tthis:
Run it in reverse.....tthat, and a little glue, ya got some new wood.
Bill
