We value your privacy.
>I didn't realize how expensive the 6" thin wall PVC fittings are. The pipe itself isn't bad, about $1.00/ft. The 'Y' and long 90� fittings run about $35.00 each.
I thought I'd spend about $100-150 on duct work and it's already at $500 and climbing. It seems like the spiral pipe is even pricier. Is there an alternative?
>Frank, at one time someone said they made their system out of the cardboard rolls they use for rugs and galvanized duct fittings. This might assist you for a while until you save for a proper system.
>Thanks, Joe. I've already bought the PVC...I just choked as I pulled out my check book and asked for the total. My shock must have been obvious because the counter guy said...."I know, it's a rip off!"
>I built my system about 3 or 4 years ago and used thin wall (Sewer and Drain) PVC. The local Lowes and the pipe and a limited selection of fittings. They had regular elbows, but no long ones. The had 45's. They also had Wye's that went from 6" to 4". The fittings were not that expensive. It seems the Eyes were about $8 and the 45's were about $4. I made a 6" main run and all the branch lines were 4". For elbows I used two 45's. At a wye I used a 45 to turn it into a swept tee.
Are you sure you got S&D fittings? I found the heavier Schedule 40 plumbing PVC and a much larger variety of fittings, but were three or four times as much money. (Schedule 40 fittings will work on S&D pipe, but you mush use an adapter ring to fill the gap in the size.
If you really want to "get into it" go to Bill Pentz (Pents?) site and read up on the pipe. They have diagrams and instructions on how to make you own fittings. If I had known that info was there I probably would have made some of my fittings, just to see if I could.
I also cobbled together parts of my system, like using a 4" duct "take off" as a connector to my jointer. I used a number of 4" "boots" for other connections and some duct elbows. (Boots are your friend.)
I think you could make your system entirely out of metal residential duct. Unless your DC is a lot more powerful than mine I don't think it would collapse.
>I think you're probably right. I know the pipe is thin wall but the fittings are definitely thick. The invoice lists the 90� ell as: 6S.DLT90 (6" S&D LT GLUE 90' ELL $37.37, and lists the wye as 6S.DY 6" S&D WYE GLUE 43.76.
I'll give them a call and see if they have thin fittings.
>I buy my PVC at Lowes, it's about the only place that carries 6" pipe and fittings.
I buy the Sewer and Drain pipe (grey or green) and fittings (white). They also sell Schedule-40 which is much heavier and triple the price.
I remember grabbing some of the Schedule-40 elbows by accident and having a heart attack when seeing their $35 price. I bought the Sewer and Drain elbows instead for less that $10.
If I recall correctly, the fitting are not interchangable. 6" SCH-40 fittings don't fit on 6" Sewer and Drain pipe. Or something like that.
>Penn State Industries sells 26 gauge metal ducting for their systems. I found it locally, fittings are a little more reasonable, the straight runs might cost a little more for a 10ft run, so it may work out about the same in price as PVC but less worries about static.
>Here's what I've done so far. The cyclone is an older one with a 1 � hp motor. The 'Y' branches off diagonally across the shop and will have 5 branches.
The original owner had a home-made (heating duct) drop coming off the filter side which I threw away. I've looked on Oneida's site for a factory piece that is a 90� curve but couldn't locate it. I'll call them on Monday.
I read on Bill Pentz's site that you should have a straight section 4' long at the intake port but that's not possible here. Does that look like $120 worth of PVC? :(
>Mark- If 6" PVC you are getting at Lowes is green or gray, it may not be S&D ASTM 2729. It is likely SDR 35. SDR 35 has the same OD as 2729, but has a little thicker wall, is slightly heavier, and is a little more expensive. Since it has the same OD, it fits S&D fittings- just thought you should know.
>Frank, you are making two friction adding-flow restricting no, no's right off the bat. A 90 bend followed by another 90 bend is one of the worst things you can do. You want to make your duct runs as straight as possible. Two solutions:
1. The best option is to raise the cyclone (I can tell/show you how to do that easily) so the inlet is at duct height.
2. If that is truly a non-starter, then use two 45s with a straight section between them to get up to duct level.
>Thanks, Alan. I used 'long' 90� elbows and thought that was o.k. I like to get rid of them but don't know how. Anything you'd care to share is most welcome!
