Planing painted wood?
>I have some walnut I rescued out of a house we are working on for my cousin. Would like to make here some sort of keep sake out of it for her. Its a 4x4 newel post, a 2x4 rail, and some 1x1 pickets. Sort of country crude at the moment. Painted with many coats of white paint, some at least fifty years old.
Will it damage my planer knives to dress it?
Re: Planing painted wood?
Rick L
Re: Lead paint...
Rick L
>is one issue to contend with. I see no problem with a couple of boards and you might want to do it outside. Little children are most susceptible to lead poisoning. Lead paint was banned in 1978 in the US so it the wood is older than that you most likely have lead paint.
Sure you will dull the blades but you won't destroy them.
Rick L
Re: Bandsaw...
Rick L
>the painted surface off would be an option.
Re: Planing painted wood? *LINK*
Bob Lang
>I would try stripping the paint off first. In addition to the lead in the old paint, titanium is a component in modern day paints. It isn't friendly to planer knives.
What might happen
Been there, done that
Terry Quiram
>and I wrecked a set of knives very quickly. You should strip the paint first. You don't have to do a real good job but get most off.
del schisler
>it sure will dull the blade's I would put on a dull set or set that isn't going to get sharpen again and take small cuts off tell all paint is off Than of coursr change blade's and plane
Agree with Del
damage no; destroy , yes!
Bill Tindall, E.TN
>The main pigment in paint is titanium oxide and it is very abrasive.
George Koch
>Barry, there is also no way in telling what's hidden beneath that paint, Nails, screws etc. George
Doug Turner
>You might consider running through a drum sander with a HEPA filtered vacuum attached. Sandpaper is less expensive than planer blades.
Ding, Ding, Ding, We have a winner......
>After reading a few of these, It dawned on me that I have a decrepit 40 grit belt for my Performax and It exhausts outdoors. Had to fasten one end with a piece of tape, but it did the job. Have to admit it might be my most gummed up belt ever. Threw it away. Was about to throw it out anyway, so it died a noble death.
I mentioned there rails were country rustic. No two pieces were the same thickness. Most were tapered. Any resemblance the 1x2 pickets had to each other was purely coincidental. Apparently they were hand sawed and chopped to a point on the ends with a hatchet to fit in the mortises in the rails and floor.
Re: Ding, Ding, Ding, We have a winner......
Alexandre Grigoriev
>Thanks for contaminating your neighborhood with lead paint dust.
That'll teach Em!!!
>Acually it goes into my DC bag and it has a 1 micron filter on it.
