We value your privacy.
>I was fortunate to locate some walnut that has been stored in a old Chicken house for the last 20 years. I was surprized to find it in fairly good shape. Other then major checking in the ends of the logs the bark is as secure as the day it was put up and no bugs or rotting can be found.
The question I have is how hard is this wood going to be to work? I have experience very dry pecan and oak and I know that turning this wood can be a difficult. Would it be best to saw into lumber. Has any one had some experience with "old" well season lumber that can give me some insight on what to expect?
I had some Walnut sawed into planks back in 1987. I was not a turner in those days, but I did have a few sawed to 16/4.
I have turned these into bowls and platters the last couple of years. I found that in my wood (Ohio) is turned just fine. No harder than any thing else if turned with a good sharp gouge. This was all air dried by the way.
>I picked up a couple hundred bf a year ago of some central IL juglan nigra that had can be dated through its stratus of bird crap. I love its color, but it was sawn poorly and dried well, crusted in digested bugs. I generally start with the old side of my planer blades or a scrub plane then on to my jointer. It hand planes really nicely, but I like to negate the dust until all the crust is gone. I won't have anything but air-dried walnut anymore, it is just gorgeous and a treat to work by hand. Enjoy the addiction.
>Be careful with the bird crap, it can contain deadly diseases. (histoplasmosis??) They treat it like toxic waste when cleaning buildings that have been infected with birds.
Rotting is unlikely in walnut, especially if it's been under a roof all this time. I suspect you will probably find bug channels under the bark, but not going into the wood itself. It's also likely that there will be lots of radial checks in the sapwood up and down the log. That's not such a big deal either, as you will want to cut off as much sapwood as possible. See if this is the case.
It shouldn't be any harder than other walnut you've worked. The age of the wood doesn't change its working properties too much, although I have some suspicions about how wood cells settle with age. I know that old guitar tops seem to become more resonant as their fibers settle. I have no idea how this actually works.
I have experience very dry pecan and oak and I know that turning this wood can be difficult. Would it be best to saw into lumber? Has any one had some experience with "old" well season lumber that can give me some insight on what to expect?
True, dry wood is always tougher than green wood for turning or for sawing. But if you would prefer to turn it, I'd say go ahead and don't let the toughness put you off. You'll have the advantage that if it is already fairly dry, it will hold its shape, so if you want round bowls, for example, you might not even have to turn rough blanks and let them dry prior to final turning.
I don't know how dry these logs actually are, but assuming they're fairly small in diameter, they are probably down in the air-dry range (say 12% - 16%), but you won't know until you saw them up. If they're big enough to get decent sized boards out of, and you could use the lumber, by all means saw them for lumber. Once you get into the wood a bit, you'll see what the checking/cracking situation is and that will be your guide as to how to proceed. But, whether you plan to do flat or round work with this walnut, don't be concerned about its age. If anything, it will be better behaved than wood that has come straight from the kiln or lumberyard. And, since it has not been kiln dried or steamed, the color should be a lot more vibrant.
