"Floor hinge" options
>I've been working over at the playhouse supervising the rehabilitation of the rigging (new ropes and cable) and doing a lot of maintenance that has been deferred for too long.
Anyway - we discovered that we have a slot in the back of the stage that extends the entire width. It goes down to the basement level. It is for painting the back drops. You lower the drop down into the slot and slowly raise it as it is painted. It now has a new batten and a manual winch.
The boards which cover the slot are 1.5" thick pine and about 12" wide and 8' or so long. I want to hinge them to make sure that they don't fall down into the slot and are somewhat secure. They are currently held down with screws.
I was figuring on using standard butt/mortise hinges or something similar with the barrel of the hinge pointed up. I would cut a mortise in the slot board and the stage floor. We have a tempered hardboard skin on the stage floor, so the barrel of the hinge wouldn't really act as trip hazard.
Does anyone have a different idea? TIA
