deWalt 735 Planer - Problem
Tony - Memphis
>I've been having a problem with my DeWalt 735. It is leaving "scratches" in the wood. Note that these are indentions, not raised areas left by nicks in the knives. I've looked at all the typical planer stuff. I even replaced the bolts that hold the knives becuase I read somewhere that someone had encountered that as an issue. New knives, etc. Nothing has gotten rid of these marks. The weird thing is, I can't for the life of me figure out where they are coming from. I've run test boards through and marked the planer where the indentions were and then raised the planer as high as it will go and looked all over. Checked the rollers, etc.
First off, has anybody else seen this? Second, has anybody done the helical cutter replacement on this planer?
I've been real happy with this planer until now. It is getting very frustrating. My boards used to come out silky smooth.
Thanks for the help.
Tony
Re: deWalt 735 Planer - Problem
>I really can't help you but I'll try anyway.
I would unplug the planer and raise the head. set a flat surface or strait edge under it and put a bright light on the far side. Slowly turn the head and watch the gap. Would not take much to make scratches. Maybe a few thousandths or a protrusion.
I have the one with the sharpenable knives and sharpen them myself. It leaves an excellent surface so the only place the spiral head would pay off for me would be on difficult wood. Still might be tempted.
larry in kansas
>Tony I`m not sure I understand what you did to when you looked at it when you raised the bed, so if tell you what I would do it may be the same. I would run a board into it as you normally do and after it starts to come out the other end shut it off. After the head stops, unplug it and then raise the bed and with the board still in take a light and see if you can see the mark. If so you should be able to pin point right where the scrach is coming from. Hope this helps. Good luck. Larry
Bart Goldberg
Bart Goldberg
>Hi Tony - I did the Shelix cutterhead upgrade. I love it. There are excellent instructions for how to perform the upgrade on the web (don't recall where, but I still have a copy). After purchasing this planer, I did start to notice that the blades would dull fairly quick, and was aware of this when I bought the planer from reading reviews. So, when I started to see the blades dull, I invested in the Shelix cutterhead versus sinking money into throwaway blades.
Bart
Indentations...
>..., except for cross-grain scalloping effects, are not likely to be caused by the knives. If these indentations are longitudinal and continuous along the length of the board, and they are on the top surface of the wood, the cause would almost have to be some kind of buildup on the rollers. The only other thing I can think of is that some part of the planer's chassis is scraping on the board as it exits the outfeed roller.
If the dents are longitudinal but short and scattered on the surface of your wood, it is more likely to be chips pressed between the outfeed roller and the wood, usually because of inadequate dust collection. Also, you didn't mention the species you're planing or whether you experience the same kind of marks on all species, but many softwoods, especially air-dry softwoods, have a lot of resin in them that can gum up beds and rollers in a heartbeat. If this is happening with softwoods, I recommend raising up the head and cleaning the rollers thoroughly with a solvent that dissolves any crud that may have stuck to the rollers or bed. Naphtha works for me, but I haven't done this on a DeWalt planer. I don't imagine there would be a problem.
I don't know if this is any help, but there it is.
Knives been sharpened?
Grant in Iowa
>Tony,
As I understand it, that planer has pins that the knives slip over to eliminate the need to adjust the height of the knives. I have no direct experience with that unit, but here goes a suggestion anyway:
Have the knives been sharpened? Maybe too much material was removed, or they have been sharpened too many times.
If there is a height adjustment of the the knives, then maybe they are set too low. I had that very issue with a DeWalt 733 one time when I set the knives too low. After consulting the manual again, I realized I had been using the knife setting jig incorrectly, resulting in the knives being too low and several dotted grooves on the workpiece.
My input on the helical knife kit is that your machine has a universal motor. To me, this means it isn't a lifetime tool. If it were me, I'd wait until I had a larger "lifetime" unit before I sprang for the extra money for the fancy knives. I have replaced my 733 with a Delta 15" planer and don't have as much tearout as I experienced on the smaller machine. Who knows why, but that is my experience.
FWIW,
Grant in Iowa
Warren E. White
>I had the same problem with my 735. It occurred after I had changed the blades. I determined that the indentations were coming from one of the bolts that hold the blade in place. (Discovered by running the board through until the indentations appeared at the outfeed end; turning the planer off and raising the cutter; peeking in to see where the indentation were.) I thought it might be that one of the bolts was loose, or there was a burr on the head of the screw, or there was some material in the bottom of the threaded hole keeping it from bottoming out.
When I tried to tighten the bolts, I ended up stripping the hex head on one, so I put another bolt in that I thought would work, but the head was a tiny bit taller than the one I took out. Even though it wasn't a lot, major indentation resulted. I ordered replacement screws from a dealer and replaced them and the problem went away.
I wish you luck. This really bummed me out until I figured it out.
I would love to buy the shelix head, but $447.00 is a bit steep for my budget. I have been quite happy with the cut I get with the factory blades, as long as I replace them when needed.
Warren
Tony - Memphis
>I replaced the bolts that hold the knives in place. I erad about a similar problem and the bolts were the culprit. So, I was pretty hopeful that the new bolts would do the trick. I noticed they were a bit different than the original bolts. But, unfortunately, they didn't help. I had filed the burrs off the old bolt heads and even marked them with paint to try and see if they were indeed rubbing, but I couldn't tell. I thought I could see a couple of rub marks on a couple of them, but it wasn't real obvious. Maybe the bolts I got were old stock? Oh well, I'm gonna have to just commit a Saturday morning to getting to the bottom of this. I ran a board through once and marked where the scratches were and thought they lined up with the screws, so I was convinced that they were the source.
Thanks for the help. These are really nice planers when they work. I was really excited when I first got it - no more snipe and glass like surfaces. I won't complain about a few ridge on less than new knives, but these scratches are darn hard to get rid of.
Tony
Re: Indentations...
Tony - Memphis
>Thanks Ellis. These are longitudinal. I get them regardless of the wood (I've run maple, cherry, poplar, etc.). I didn't pay much attention to them when it first started. I just assumed they were ridges and I shifted the knives. That didn't work, so I tried new knives. That didn't work, so I replaced the bolts. As siad in another post, I'll have to just commit a Saturday morning to figure this out. After Christmas....
Tony
William A. Roland
William A. Roland
>How is you dust collection?
Joanne in Pt. Pleasant, PA
>I have an older DeWalt planer. Somehow I managed to get a scratch in the bottom plate the wood rides on. It was putting scratches in the bottom face of the wood I was sending through. I replaced the plate and have not had that problem. Are you flipping your wood over to plane both sides? Are you sure your scratches are on the side against the knives? Could this be your problem?
Does it look like this?
Ed Mulligan, Cape Cod MA
Tony - Memphis
>Real good. Although this unit has its own that will shoot the chips across the shop if the ose comes off!
Tony
Tony - Memphis
>Thanks. These are definitely being created on the top. I do flip though to try and remove equal amounts off each side when I can. Not sure if that makes any difference, but that's what I do. Ont he one hand, planing is a chore, on the other hand, it can be very exciting ad rewarding to see that nice clean beautiful wood come out the other side - like magic!
Tony
No
Tony - Memphis
>Mine run the whole length of the board.
Tony
Idiots guide to removing planer scratches
>Wonder what would happen if you planed a board to a known thickness, say the 3/4 setting on the planer, remove the knives and bolts, etc -- glue a piece of fine sandpaper or Emory cloth onto the board and ran it through the planer. Let it sand/grind off whatever the offending part is. Seems like the sort of thing I would do, right before I bough a new planer.
del schisler
>i guess we are talking about the indentation's are on the planed side and not on the botton? If they are in the same place ? cant be dust or chips Take a pic if you can and post If you change all part's on the cutter head Their is nothing left Both knives in right ? They will go in 2 ways right and wrong Just talking or thinking Their is nothing left to rub the board Be interesing to get to the botton of the Mystery
Tony - Memphis
>yes, it is on the planed side and always in the same place. The knives on the 735 are fixed one way and can slide around an eigth the other to allow shifting out nicks. Three knives on this model. Makes blade changing a snap - expensive, but a snap.
Yep, I'm anxious to get to the bottom of this too. I've checked all the common sense stuff, but I may have overlooked something as I don't have much of that! Even Barry, who doesn't even know me, could sense that I am an idiot! See his post above "Idot's Guide...". I hope its something realyl unusual so I don't look really stupid when (hopefully) I post the fix!
I'ev got two Christmas presents going right now and all the other seasonal obligations, so it may be after Christmas. New Years weekend might be a good time since I'll be off an extra day.
Tony
Re: check the depth gauge
Brian in Brighton
>Your depth of cut gauge on the incoming side might be stuck and it grinding into the wood as it moves under it.
Brian in Brighton
Warren E. White
>Tony, did you ever figure out what was giving you the problem with your planer? If so, what was the fix?
