Kudos to System Three Epoxy
>I've been posting my gripes about Epoxy I bought from the Borgs.
Bought some System Three from WoodCraft. Appears to be nearly identical to the Loctite stuff from the Borg. (Kinda makes you go Hmmm?). But, I mixed it up, just eye balled the equal proportions, added some powdered dye to make it walnut colored and used it on the dovetails on the toy box I am working on. Its the one hour stuff. I was frantically slathering it on the various parts of the joints, trying to stay ahead of the set time. It acted like a lubricant. The joints I had had to tap together with a rubber hammer slipped into place like silk. Clamped it up and squared it and left it alone for about five hours. Went back and cleaned it up. The stuff hardened exactly as it should have. Or at least as I thought it should. Next time I will clean up the squeeze out sooner, but that was part of the learning curve. (I thought it would be better to let it set up a bit rather than smear it all over creation.)
Not sure why, but it seemed much better than the borg stuff.
Now if I could just figure out how to handle it with getting it from rear end to eyebrow. Its a given I am going to have some one me, so I just wallow in it when I start.
Re: Kudos to System Three Epoxy
Jesper, Denmark
Re: Two comments
Jesper, Denmark
>1. Wear nitrile rubber disposable gloves (it's the blue ones) while handling epoxy. It may not feel like it now, but some people develop a sensitivity to epoxy over time and multiple exposures, just like poison ivy.
2. Wait with clearing off the excess till it has set, or you will have to sand off more, as the epoxy penetrates the wood. DAMHIKT! It also helps to mask off the ajoining areas with broad masking tape to avoid smearing the epoxy too far.
And just for good measure, it helps adding a little colloidal silica to the mix to increase the viscosity, so it does not run as much. The colloidal silica does not do anything to reduce the bond strength, but don't puff too hard when mixig, the stuff floats into the air at the least bit of breeze.
Re: Two comments
>Thanks for the suggestions. I was wearing gloves, but the phone rang in the middle of this and took the left one off.
I also used it to fill a gap that had opened on a bowl. Put blue tape around the gap and dabbed on the epoxy. Used my dust collector to suck it through the crack. I was surprised that after I got it through the crack it would continue to settle and ooze through and come out the other side. The crack was thin enough that a business card would not go in it. Should have sealed the other side with tape as soon as it came through. I need some of the colloidal stuff. Much to learn.
When I first read this post headline
>in conjunction with your previous message, I thought you were going to say you'd epoxied your tummy wound closed.
Everyone knows that duct tape is the preferred bandaging method.
Thanks for the information on this epoxy. I've never used anything but the hardware store stuff.
jesse cloud
>If you want to apply a small amount of glue to a small area (e.g., cracks, dovetails), take a 1/4 dowel and sharpen it with a pencil sharpener - use that as an applicator.
I have used CA....
>to close cuts. Read about surgeons using it. Warning. The type we use in the shop gets HOT when it sets, especially with the accelerator. It will cauterize the wound at the same time. Did I mention HOT?
>I was using a flux brush. You can buy a bog of them for about tern cents each.
I will try the dowel idea though. Thanks.
Paul Woolson
>Barry, I use a lot of epoxy, mostly as pore filler. Be very careful. As said before, it's a known sensitizer. Which means you can be using it willy-nilly today, and tomorrow you are in the E.R. with your throat swelling shut. It's pretty serious and much more common than you might think. I know two other guitar builders than can never use the stuff again as, once the reactions start, they get progressively worse each time. I err on the side of caution and use a Tyvek suit, nitrite gloves and a full fact respirator (full face shield).
Now, on a happier note...if you like the System 3 stuff, you might also try West Systems stuff. They have a fast and slow hardener which will buy you more time in a situation like you had. They also have pre-measured pumps that just screw onto the cans. One pump of each is a perfect 5:1 ratio. Very fast and easy. I find the West Systems holds better but that might be because of the accurate measurements.
Bart Goldberg
Bart Goldberg
>Barry, I am curious what problems you had with the Loctite epoxy. I use the 5 minute stuff when I need to have a faster set time, or just need a small amount.
I did an experiment with this stuff recently where I created three different mix ratios. I used less hardener than resin, approx. equal hardener and resin, and more hardener then resin.
All three eventually set, but if you don't use enough hardener, the epoxy will get rubbery and take a really long time to fully set or just stay rubbery.
Regards
Bart
>Moistly I have had problems with it setting and not being rubbery.
I made some canes and epoxied the fittings on them. As I recall, I think the epoxy was above and beyond. In theory you could just screw these things together. I was making them out of the clients walnut that had really wild grain and I tried to make the holes very slightly loose so as not to crack the wood. Added epoxy to make up for the slack. We are talking very slight slack, few thousandths. Put the cans together and let them cure for at least 24 hours. Started to put the finish on and was hanging them up by the fittings. They literally fell apart. One that I thought was fine fell apart on the client. Had to remake it.
When I was using the Loctite in the bottles I was so gun-shy I added a little extra hardener. I used the whole bottle of resin and had about 1/8 of the hardener left.
My shop may have been too cold. Its comfortable, but reading the label indicates the epoxy likes it warmer than I do. 65 or 70 suits me well. Apparently the epoxy likes it to be 75 or 80. This time I heated the shop and the project up to about 75 and glued it up and left it with the heater running.
I think I have a lot to learn about epoxy. I thought the stuff from the Borgs would have been designed to be fairly forgiving and somewhat idiot proof. I must be one of the better idiots.
I was trying to figure out some super accurate way of measuring the two components of the System Three stuff, but the guy that owns the local WoodCraft scoffed at the idea and said he just eyeballs it. I took him at his work and did it. Same thing I have done with the Borg stuff. Worked this time.
learning to use West system
>I've been using System 3 and the borg epoxies for years. I just purchase some West System along with the various thickners. I'm having to get used to it. It is much thinner straight out of the cans and seems to take forever to harden. I just got some of the fast hardener but it's more like 30 minutes instead of the borg 1 minute or 5 minute.
I think I will like it once I get used to mixing it but it is a pain having to mix the thickener with it. some of the Thickeners change it's color but you can always add various colors to it. Of course if you need clear then leave it thin and figure out a way to damn up the area so it won't run on you.
take a look at this *LINK*
Bruce, a MN Galoot
>Gougeon Bros, mfgs of West System, have a nifty newsletter online that will tell you everything you want to know, plus bunches more.
epoxyworks
Bart Goldberg
Bart Goldberg
>Barry, I often use the standard System 3 epoxy, 2 to 1 ratio and in small batches. For me, the premeasured pumps require I make more than I want. So, for measuring purposes, I use these little clear plastic measuring cups that are made for just this. This seems to work quite well. In fact, I generally reuse these cups once the epoxy hardens. I can usually just push out the hardened epoxy from the cup and reuse. I also intentionally leave left over epoxy in the measuring cup so I can see when it has fully hardened. I also agree that, in general, epoxy likes warmer temps to set properly.
Happy Woodworking
Bart
Bart, where did you get the little cups?
For canes & anything subject to shearing/twisting *LINK*
David Barnett - SW FL Gulf Coast
>I've found nothing beats golf club shafting epoxy. It's also great for non-threaded screw inserts, rod building, etc. I like the black stuff for most work. Almost as good is G1 if you need something with a natural color epoxy glue line (such as my benchtop), but the black looks crisp on a finished product. System Three bought out Industrial Formulators (who makes G1, G2, etc.) but I think it's still made and available from Lee Valley.
I use those fast cure epoxies precisely because they fail more easily than slower cure versions, but my use is non-structural -- cold dopping gems for faceting. Freeze 'em or soak 'em in Attack and off they pop.
My go-to epoxy is West Systems for everything else. Tip: if you use colloidal silica, it's much cheaper to buy it from just about any ceramic supply. I buy 25lbs 300 mesh at a time for a few dollars (I use it for refractory moulds in glass casting). Treat silica with respect. It easily becomes airborne (colloidal = like smoke). You breath it and you could be very sorry. Even just a little can give some people silicosis.
Golf club shafting epoxy
Bart Goldberg
Re: Bart, where did you get the little cups? *LINK*
Bart Goldberg
>Here is another link
Epoxy Cups
Thanks
Jesper, Denmark
Re: Two comments
Jesper, Denmark
>Both west System and System three have the various additives for sale. west also have some pretty good instructions on their website.
